ᐅ What type of foundation is suitable for a prefabricated garage?
Created on: 20 Feb 2019 14:30
Golfi90
Hello everyone!
I am planning a prefabricated garage from the company Garagenrampe for our house.
Apparently, there are two options for the foundation of this garage.
One option is a concrete slab foundation, and the other is strip foundations.
Which option would you choose?
Is it better to have a full slab poured and then lay tiles on top?
Or would you go for strip foundations and then pave around the garage?
Golfi9020 Feb 2019 16:38
No, the garage does not have a floor.
The precast elements will then be sealed towards the floor.
O
Obstlerbaum
20 Feb 2019 17:00
In this case, a concrete slab foundation would be the only option for me personally.
11ant20 Feb 2019 17:05
Golfi90 schrieb:
a steel wall garage that is plastered and therefore looks like a solid concrete garage.
My landlord used to manufacture garages and halls himself and did not offer plaster, only a sand finish — presumably he shared my skepticism about plastering steel. The texture can match plaster — also in long-term appearance — and except for the panel joints, the material doesn’t reveal itself. However, it should be noted: there is a local pumice “prefab” garage manufacturer and within the region one (formerly two) concrete garage manufacturers, so the small price difference between a high-quality (and consequently more elaborate) plastered steel garage and a precast concrete garage probably made it “practically impossible” to offer both in parallel.
Obstlerbaum schrieb:
In that case, for me personally only a concrete slab would be an option.
That’s where two perspectives clashed, since the steel garage is also valued for the advantage of easy relocation.
Golfi9020 Feb 2019 17:08
It is definitely not planned to move or enlarge the garage in a few years. It will be built directly on the property line and represents the maximum allowed size.
In my opinion, there should also be a concrete slab underneath...
O
Obstlerbaum
20 Feb 2019 17:09
That brought two worlds together, as the steel garage is also valued for its advantage of easy relocatability.
A garage is not seasonal decoration. It is installed and remains in place.
Musketier20 Feb 2019 17:41
Golfi90 schrieb:
In my opinion, a foundation slab should also be placed underneath...
Haven't you basically answered your own question then?
