ᐅ Which adhesive do you think offers the best chance for a successful repair on the KALLAX?
Created on: 3 Mar 2017 09:14
NESUSO
NESUSO
3 Mar 2017 09:14
Hello everyone, I have a specific question about repairing KALLAX shelves, as I recently had an accident and one of the side panels broke. My question is: which glue would you consider the best option for repairing KALLAX, especially when it comes to bonding the particleboard with the outer laminate?
It’s important to me that the repair is not only strong but also as durable as possible, since the shelf has to hold several kilograms (pounds). I’ve heard about wood glue, superglue, and special construction adhesives. I’m also interested if you know any tricks to improve the glue’s bonding strength, such as surface preparation or post-treatment.
Thanks in advance for your opinions and experiences!
tralo45
3 Mar 2017 09:47
Hello NESUSO, first of all, get well soon with your furniture piece! 🙂 Regarding glue for KALLAX shelves, there are a few important points to consider. The outer layer is usually a melamine coating, which is quite difficult to bond because it is very smooth and water-repellent. Therefore, I would recommend roughening the bonding surface well, for example with fine sandpaper.
As for the glue: wood glue (PVAc) works well with traditional wood veneers but often has adhesion problems with melamine. That’s why a specialized assembly adhesive based on MS polymer or a two-component epoxy adhesive is usually more effective. Cyanoacrylate glue (super glue) with a plastic base can bond quickly but tends to be brittle and does not withstand stress optimally.
A tip: apply the recommended amount of assembly adhesive, press the parts firmly together, and allow the glue to cure for 24 hours. This helps to avoid weak spots. Hope this helps you!
barle
3 Mar 2017 10:16
I would recommend construction adhesive (neutral cure silicone or MS polymer based). Wood glue is usually not sufficient for KALLAX with melamine coating. Lightly sand the surface and secure it firmly.
Guyju
3 Mar 2017 11:22
Hello NESUSO, to answer your question in more detail, I see the repair process in several steps:
1. Surface preparation: An important step that is often overlooked is preparing the surfaces. Since KALLAX shelves are melamine-coated, you should gently but thoroughly roughen the broken area with sandpaper (grit about 180-220). This significantly improves the adhesive bonding.
2. Choice of adhesive: Classic wood glue usually adheres poorly to melamine because it is designed for porous wooden surfaces. Better options are assembly adhesives or repair adhesives based on polyurethane or MS polymers. Alternatively, a two-component epoxy adhesive also works if it needs to be especially strong.
3. Application: When applying the adhesive, pay attention to the correct amount—not too thin, but not too thick—to allow proper curing. Clamp the parts together with clamps or quick-release clamps for at least 12-24 hours.
4. Post-treatment: Post-treatment is usually not necessary, but after curing, you can smooth the surface with very fine sandpaper and refresh the coating if needed with foil.
In summary: In my experience, using an assembly adhesive is the best way to ensure strength and durability when repairing a KALLAX shelf. I would only use wood glue if the coating is damaged and the bond is made on bare wood.
I hope this helps with your project!
Teonon
3 Mar 2017 12:03
I completely agree! 🙂
I’m really impressed by how practical and versatile construction silicone is! It adheres very well to smooth coated surfaces, is easy to work with, and forms a strong bond after curing.
So, if you want your KALLAX to last even longer, make sure to spend enough time pressing and clamping it firmly. That makes all the difference! Good luck with the repair – you’ll do great! ;-)
bupar
4 Mar 2017 08:42
For factual classification: KALLAX particle boards are usually coated with melamine resin, which results in a hard surface and low surface energy. This makes adhesion difficult for common polyvinyl acetate (PVAc) wood glues.
Adhesives based on reactive polymers or epoxy are recommended. Two-component epoxy adhesives create a durable, highly resistant bond and can accommodate small surface irregularities well.
Assembly adhesives based on MS polymers also offer good adhesion and are more elastic, which helps stabilize areas with low stress.
Pretreatment by sanding (grit 180 to 220) significantly increases the surface area for mechanical grip.
The bonding surface must be dust-free to avoid compromising adhesion.
Conclusion: For durable and strong repairs on KALLAX, I recommend two-component epoxy adhesives combined with proper surface preparation. This is practically the industry standard for such repair applications.
