ᐅ KALLAX Shelves Splintering After Reassembly – Any Suggestions?
Created on: 21 Sep 2020 08:57
fenule
I recently assembled a new KALLAX shelving unit, but unfortunately, I immediately noticed that some of the shelves started to chip along the edges when inserted. This mainly occurs where the shelves are pressed into the mounting grooves. The load is still minimal, as the unit is practically empty. My question is: Is this due to poor workmanship, or did I make a mistake during assembly? Are there any tips on how to reinforce the shelves afterward or protect them from further chipping?
I carefully inserted the shelves, did not use any force, and fastened all screws according to the instructions. Still, visible damage is already apparent – this won’t hold up for long.
Has anyone had similar experiences or can provide a professional assessment? Thank you very much!
fenule schrieb:
I’m not familiar with sanding the edges; that might actually be something to try.That is indeed a very good approach. Often, in inexpensive furniture, the edges are only minimally deburred, making the coating more delicate. Light sanding with fine sandpaper (grit 220-320), applied only to the cut edges, can help reduce stress in the material and prevent splintering.
If possible, you can test sanding on an inconspicuous spot beforehand to see how it affects the appearance, since the edges of KALLAX are usually coated with melamine resin.
Small amounts of wood glue can also be applied to broken areas to stabilize the fibers. Then press the surface with some weight until the glue dries.
After sanding, you can seal the edges with furniture wax or an appropriate finish. This also helps to keep moisture out, which can be problematic for particleboard.
I have found that the shelves in KALLAX units are especially sensitive due to their large span. Do you have the option to add additional supports, such as beams or clamps?
Hello fenule,
I can fully understand how frustrating this is. I want to emphasize again that when working with particleboards, you generally need to apply pressure over a wide area—these materials are sensitive to localized pressure or twisting.
It is especially important that the parts are assembled on a flat and clean surface. Even slight warping or dust on the joint surfaces can make snapping the pieces together more difficult and require more force.
Also, with the IKEA KALLAX shelving system, there can sometimes be minor tolerances; this is normal. In such cases, light sanding can be helpful, but always do this carefully and minimally.
Would you like to know how to improve the stability of already damaged shelves? If so, just ask—I’m happy to provide more tips 🙂
Good morning,
I’m happy to provide you with a clear step-by-step guide to help you solve your problem:
1. Inspect all parts for any manufacturing defects (dents, scratches, brittle edges).
2. Lightly sand the edges with fine sandpaper (preferably grit 320), always sanding in the direction of the grain.
3. After sanding, gently remove any dust residue with a damp cloth.
4. Frozen wood glue or wood filler can be carefully used to fill cracks and splintered areas.
5. Clamp the filled spots firmly with a clamp or pressure clips until fully dried.
6. Afterwards, you can apply a transparent furniture edge band or edge protection film – this provides optimal protection against further damage.
During assembly, make sure not to force parts out of alignment and install shelves evenly. A light sanding of the insertion tabs for the fastening holes can make assembly significantly easier.
If you have any questions, I’m happy to help!
NoValentin22 Sep 2020 09:06fenule schrieb:
Some of the shelves chip at the edges when being installed.I would also attribute this to material quality and applying too much pressure during installation. Try smoothing the edges lightly with fine sandpaper and insert the shelves very carefully.
fenule schrieb:
I couldn’t completely avoid slight misalignment since the parts are rather difficult to fit.This is often the cause of chipping. If the material is stressed at an angle, the coating tends to crack along the edges.
For future installations, I recommend lightly scuffing all connection points with sandpaper beforehand and ensuring a clean, flat surface during assembly.
Additionally, you can try gently tapping the shelves in place with a rubber mallet instead of forcing them in.
LAURE-TA schrieb:
Frozen wood glue or wood filler can be used to carefully fill cracks and splintered areas.Good tip, but I would like to add that you absolutely need completely dry edges before filling, otherwise the repair won’t hold well.
You can also ideally prepare the damaged areas with fine sandpaper and then apply epoxy resin adhesive. It cures very hard and durable and protects against further breakage.
Another point: For floors with heavier loads (e.g., heavy books), it is advisable to add reinforcements afterward.
How heavily do you load the shelf? Are the damaged shelves on lower levels with higher load? That information would be important to know.
