ᐅ Which type of handles should I use for IKEA Platsa cabinets?
Created on: 28 May 2019 08:33
Finnjo
Finnjo
28 May 2019 08:33
Hello everyone! I am about to assemble my IKEA Platsa cabinet and would like to choose the handles myself, as I find the standard ones a bit uninspired. My question is: Which handles do you specifically recommend for IKEA Platsa to get the best result both visually and functionally? Important factors for me are ergonomic handling, style compatibility with the often modern Platsa fronts, and of course ease of installation—especially so that adapting to the existing carcass is not too complicated. I look forward to tips on which types and materials of handles have proven reliable, as well as information on dimensions so I can ensure the correct drilling distances. Thanks in advance for your help!
DUKUSU
28 May 2019 09:01
Hey Finnjo, glad to see you’re diving so deeply into the handles! For Platsa, I mainly use metal handle strips with a matte finish. They not only look super stylish but also feel really comfortable to hold. 🤩 Installation is quite simple – most of the time, the drill holes from IKEA handles fit directly or can be easily adjusted.
Personally, I think aluminum handles or brushed stainless steel really highlight the modern design of Platsa. And here’s a tip: with longer handle strips, you can choose the height freely, giving you a lot of comfort when opening. Don’t get thrown off by the standard handles – you can easily upgrade them and totally enhance your interior! Good luck!
BERONAR
28 May 2019 10:46
I want to offer a slightly different perspective: Why spend extra money on special furniture handles when the standard handles from IKEA generally work well? In my opinion, the whole hype around "stylish" handles is often just marketing.
Finnjo schrieb:
Which furniture handles do you specifically recommend for IKEA Platsa to get the best both in terms of appearance and functionality?
The "best" is often very subjective. I advocate for pragmatic solutions where the cost-benefit ratio makes sense. You can definitely use inexpensive universal handles as long as they fit technically and serve their purpose. Everything else is often overengineering.
Gino38
28 May 2019 14:22
Regarding ergonomic handling and installation: With the Platsa system, it is essential that the handles fit the existing drill holes or that the positions match exactly. The standard drill holes are 128 mm (5 inches) center-to-center for most drawer fronts.
- Handle bars or pull handles with a 128 mm (5 inches) drill spacing are ideal.
- In terms of materials, I recommend stainless steel or aluminum because they are durable and easy to maintain.
- Plastic handles often appear less premium and may wear out faster.
Functionality and style are important, but the craftsmanship aspect should not be underestimated: measure precisely and ensure compatibility to avoid unnecessary rework.
mifra
29 May 2019 07:18
Building on the previous contributions, I would like to add that for IKEA Platsa, handles with a standard hole spacing of 128 mm (5 inches) are recommended, as these fit best with the pre-drilled holes.
- For optimal ergonomics, longer bar handles are preferable because they distribute pressure more evenly.
- The choice of material should focus on durable and wear-resistant options, preferably metal.
- Visually, I recommend matte finishes, as they make scratches less noticeable.
Furthermore, it is important to ensure that wood chips or unevenness around the drilled holes are removed during installation to guarantee a precise and secure fit.
Lyndon55
29 May 2019 10:02
Hello Finnjo, I’m happy to give you a step-by-step recommendation on how to choose suitable handles for IKEA Platsa:
1. Check measurements: Measure the drill hole spacing on your Platsa fronts (usually 128 mm (5 inches)).
2. Style and material: Choose a material that matches your interior, e.g. stainless steel for a modern look or black metal handles for an industrial style.
3. Ergonomics: Make sure the edges are rounded and not too sharp, and that the handle height allows your fingers to grip comfortably.
4. Installation: Follow clear instructions, and if uncertain, consider getting help from a professional.
Common mistakes include incorrect drill hole spacing and ignoring handle height, which can be frustrating later. Following this approach will keep you on the safe side.
