Hello everyone, I am currently considering which drawer slides are best suited for the Ikea Pax wardrobe. It is important to me that the slides are sturdy and provide smooth, quiet opening and closing. Additionally, I want them to be as flexible as possible in terms of installation, since I often rearrange the interior. Does anyone have experience with specific brands or models that work particularly well with the Pax system? Which slides are durable and can easily handle somewhat heavier loads? I look forward to your recommendations, preferably with a brief explanation of why these slides are especially recommended.
Hello Ratko, I find your question very clearly formulated. For Ikea PAX, I especially recommend the drawer slides from Blum, particularly the TANDEM or MOVENTO series.
- These slides are very sturdy (up to 30 kg (66 lbs) and more per slide)
- They feature an integrated soft-close function, which makes opening and closing very quiet
- Installation is flexible thanks to the simple clip system
Another advantage: they can be easily adjusted with standard tools, which can be important when retrofitting in PAX cabinets. Especially if you frequently reorganize the interior, it is convenient that the slides are also vertically adjustable.
If you want, I can also give you tips for precise installation in case you want to do it yourself.
Hello Ratko, I would like to add some points to consider when choosing drawer slides for the PAX system to ensure they fit properly and last a long time:
- Load capacity: Most Ikea drawers are fairly lightweight, so make sure to choose slides with a load capacity of at least 30 kg (66 lbs) if you plan to store clothing along with heavier items.
- Length adjustment: PAX cabinet depths usually range from 58 to 60 cm (23 to 24 inches), so you need slides that match mechanically and in length precisely.
- Mounting system: Clip-on slides are recommended because they install without screws and are easier to clean.
- Soft-close mechanism: Invest in versions with damping, as this significantly improves both durability and user comfort.
Tip: If you cannot find suitable slides for your apartment’s location, replacement is often easier with standard 35 mm (1 3/8 inches) drill holes on the sides, since PAX already uses 35 mm hole rows.
In summary: Blum MOVENTO offers everything you need but is somewhat expensive. Hettich Quadro provides similar quality at a lower price but is not as quiet. I would advise against other no-name slides because they often lack precise fit and long-term durability.
Nadine schrieb:
Another advantage: They can be easily adjusted with standard tools, which is sometimes important for retrofitting in PAX.This is a crucial point I want to emphasize. Especially with PAX, it’s often necessary to adjust drawers afterwards because the doors or drawers can hang slightly. This is easily possible with Blum and Hettich thanks to their modular adjustment mechanisms.
One more tip: When purchasing, pay attention to the width of the drawer. PAX frames are often 50 cm (20 inches) wide, so you should look for drawers with a matching size (around 45 cm (18 inches) usable width) to ensure smooth operation. Custom sizes are hard to find.
If you don’t want to replace the entire system, you can also use special inner drawers that attach directly to the PAX side panels. These are available from third-party suppliers and generally fit very well.
