ᐅ Are there alternative replacement parts for Ikea Brimnes that fit better?
Created on: 26 Aug 2019 18:03
Debbiedu
Debbiedu
26 Aug 2019 18:03
Hello everyone, I recently purchased an Ikea Brimnes bathroom cabinet set and am generally satisfied, but some replacement parts like door hinges and drawer slides don’t fit perfectly — the tolerances seem a bit high and the assembly is not entirely intuitive. Therefore, my question to the community: Are there actually alternative parts for the Ikea Brimnes, meaning compatible replacement or upgrade parts from third-party suppliers that fit better and are of higher quality than the originals? I mean hinges, handles, but possibly also the rails or other fasteners. Perhaps some of you have had similar experiences or even recommendations for suitable alternatives. I look forward to your opinions and tips!
TAUPLO
26 Aug 2019 18:47
Hey Debbiedu, that’s a good question! 😄 Brimnes is pretty much a typical IKEA product, so you can sometimes tell that the components are designed more for mass production than fine-tuning. From my own experience, I can say that I actually replaced the hinges with some from Blum, which fit surprisingly well and make opening much smoother. Of course, it requires a bit of DIY work, but the quality is simply better. For the handles, I switched to stainless steel right away—it looks nice and feels sturdier. So if you’re willing to experiment a little, there are definitely options that can work better than the original.
LEVI41
26 Aug 2019 19:15
Regarding alternative parts for Ikea Brimnes, I can contribute the following: Hinges come in standardized sizes, particularly 35mm (1.4 inches) drill holes, which often correspond to brands like Blum, Hettich, or Grass. These brands offer higher quality and smoother motion. However, it is important to note that the drilling patterns of Brimnes sometimes differ, which requires similar adjustments or modifications.
Regarding drawer slides, models with soft-close are definitely an improvement; for example, Hettich Quadro is one of the most well-known alternatives. Original handles can be easily replaced with standard or designer handles, where precise measurements are less critical.
neoren
26 Aug 2019 19:38
I only replaced the hinges on the Brimnes with Blum derivatives. They fit well; just make sure to measure beforehand. It’s worth it.
semuneo
26 Aug 2019 20:22
It sounds like you’re genuinely trying to find a practical solution, which is great. I’ve also had issues with Ikea cabinets, especially with the fit of the drawers. What helped me was patience during assembly and being open to small adjustments—such as lightly filing or fine-tuning the hinges. Alternative parts can be useful, but sometimes it’s also a learning process until everything fits perfectly. How are you equipped in terms of tools and DIY skills?
REPITAR
27 Aug 2019 07:52
Hello Debbiedu, I would like to give you a brief guide on how to find and test alternative parts:
- First, measure the exact dimensions of the existing mounting points and drilled holes.
- Then check if standard hinges, for example from Blum or Hettich, are compatible (e.g., 35mm (1.4 inch) hole spacing).
- For drawer slides, you can choose soft-close models from full-extension manufacturers, which often have better running quality.
- For handles, the screw spacing is crucial, so make sure to verify the measurements, as Brimnes sometimes has specific distances.
- A tip: When removing the old parts, take all measurements and photograph them carefully so you can search for replacements more precisely.
If you want, I can also provide you with more specific sources for individual components.
