Hello everyone, I am planning my living room with new Ikea Besta units and I’m a bit uncertain about the choice of colors for the fronts. I am especially interested in which colors work best for Besta fronts if you aim for a timeless, modern design that complements both light and dark furniture in the room. The color should also be easy to maintain and able to hide scratches as much as possible. Which colors would you recommend and why? Are there any suggestions for more unusual color combinations or trends that go well with Besta? I look forward to your expertise and experiences.
Hello Luca61, your question is very detailed, which makes it easier to give targeted recommendations. For Besta fronts, matte colors are especially suitable because they make fingerprints and small scratches less visible compared to glossy surfaces. I suggest:
- Matte white if you want a bright, clear feeling in the room. It goes well with light walls and creates a sense of spaciousness.
- Matte anthracite or dark gray for a modern yet neutral look that complements wood or metal elements.
- Sand or taupe tones if you want to add warm accents; these feel less harsh than pure white or gray.
For maintenance: colors with slight texture or matte finishes are best because they show less dirt.
I would limit bold colors to accent parts, for example individual compartments in petrol or mustard yellow, to make the space more interesting without overwhelming it.
Hello everyone, I’d like to add a brief guide on choosing colors for Ikea Besta fronts to achieve long-lasting satisfaction:
1. Color Selection:
- Neutral shades such as white, gray, or beige are excellent for a timeless base.
- Dark tones like anthracite or matte black make strong statements but should be thoughtfully placed in the room due to their intensity (ensure sufficient lighting).
2. Surface Texture:
- Matte finishes are advantageous because scratches and fingerprints are much less noticeable.
- High-gloss fronts look more elegant but require regular maintenance and show wear more quickly.
3. Color Psychology and Spatial Effect:
- Light colors visually open up the space.
- Dark colors create a cozy atmosphere and provide contrast to light walls or floors.
4. Care Instructions:
- Colors with some surface texture are less sensitive.
- Especially for light colors, use gentle cleaning agents to avoid yellowing or stains.
In summary, I recommend matte, neutral colors for everyday use that blend harmoniously with the room design and feature durable material.
1. Color Selection:
2. Surface Texture:
SAWYERR schrieb:
For timeless design, white or shades of gray always work very well.However, I find that too much white in a room can quickly feel sterile and boring. Especially with Besta, which is so versatile, you should also try bolder colors. Dark blues or even deep greens can create real highlights without looking tacky.
minan schrieb:
I would limit unusual colors to accent parts, for example individual compartments in teal or mustard yellow.That’s too conservative. Ikea is all about personal style. So why not choose an entire front in a strong color? It’s important to have a matte finish, which keeps the look elegant at the same time.
My experience with Besta fronts confirms the recommendations to choose neutral shades, especially matte gray tones, because they are durable and suit a wide range of interior styles. It is a mistake to follow trends alone, as color preferences and the overall feel of a space can change quickly. Therefore, it is better to opt for colors that will still look good in a few years.
Another important factor is the combination with the floor and wall colors, which must always be considered; otherwise, even the most attractive fronts can quickly appear out of place.
