ᐅ Which BILLY shelves are especially suitable for heavy books?
Created on: 21 Mar 2023 11:07
Pefefar
Pefefar
21 Mar 2023 11:07
I want to get several BILLY shelves from IKEA to store a large collection of heavy reference books and textbooks. I’m wondering which versions or designs of the BILLY shelves are best suited for the weight of these books. Stability and load capacity of the individual shelves are especially important to me, as well as any tips on reinforcement or suitable accessories.
Can you share from experience which models work best for heavy books? Do you use specific shelves, reinforcements, or system combinations that make the shelving more durable and able to handle the load? I want to avoid the shelves sagging or the entire unit becoming unstable.
I’m looking forward to your opinions and practical advice!
JAFUHAU
21 Mar 2023 12:14
Hello Pefefar,
I know this problem well! Heavy books can really be a challenge for shelves. My standard BILLY shelves started to sag over time, even though I only had about 20 kg (44 lbs) per shelf.
Pefefar schrieb:
I’m especially interested in the stability and load capacity of individual shelves
I can only agree with that, because without proper reinforcement I also see it as a concern. I have now installed the support bars that IKEA offers as an accessory. That helps a lot.
What also worked for me is choosing a shelf with a depth of 28 cm (11 inches) instead of 40 cm (16 inches), and placing more shelves side by side. This spreads the weight better.
Maybe you’d also like to share which books you have exactly. Thickness and weight often vary quite a bit.
I hope this helps you a little! For me, it’s always a trade-off between appearance and function. 🙂
Peose
21 Mar 2023 13:22
Hello everyone!
I find it really fascinating how much weight these shelves sometimes have to hold! 🙂
From my own experience, I can say: the standard BILLY shelves already support quite a bit, but if you have many thick reference books or atlases, it’s worth reinforcing the shelves with additional wood panels or MDF. Just attach them underneath the shelves, it makes them much stronger!
And honestly: I think the idea of shorter shelves is brilliant! It distributes the load much better and also looks great.
And don’t forget: securely fasten the shelves to the wall, this is very important, especially when the load gets really heavy!!!
That’s just brilliant! 🙂
faso31
21 Mar 2023 15:47
I would like to clarify a few points:
JAFUHAU schrieb:
instead of just using a 40cm (16 inches) deep shelf, use a 28cm (11 inches) deep shelf and place shelves side by side more often
This is certainly a practical solution, but the load capacity primarily depends on the material and construction. If you look at the technical specifications from IKEA, the BILLY shelf has a maximum load-bearing capacity of about 15 kg (33 lbs) per shelf – although this can vary depending on size and use.
When dealing with heavy books, people often overestimate the importance of shelf thickness alone. Just as important is a secure wall mounting and distributing the weight across several shelves.
Peose schrieb:
reinforcing the shelves additionally with wood panels or MDF
Such reinforcement makes sense but should be well adapted to the shelf structure; otherwise, you lose the advantage of BILLY’s easy adjustability.
My advice: a combination of secure wall mounting, reinforcement of the shelves with additional battens (or MDF), and, if necessary, extra central supports for especially heavy loads.
BOSULE
22 Mar 2023 08:03
Here are some additional facts:
The standard BILLY shelves made of particleboard with a foil coating actually have a load limit of about 15 to 20 kg (33 to 44 lbs) per shelf, depending on the shelf depth and width.
For heavy books, I recommend the BILLY model with 80 cm (31.5 inches) width and 28 cm (11 inches) depth, as it provides better load distribution.
Additionally, there are "stability strips" accessories from IKEA that can be attached to the underside of the shelves – these significantly increase the load capacity.
It is also advisable to securely mount the bookshelf to the wall using the included fittings, as otherwise, the shelf can easily tip over.
Another tip: if possible, the lower shelves should carry heavier loads than the upper ones to maintain stability.
This allows for a high degree of load-bearing capacity without needing to resort to special shelving units.
SUBEN60
22 Mar 2023 09:45
Short and factual:
The standard BILLY shelves are made of 16 mm (5/8 inch) particleboard. The load capacity is around 15 kg (33 lbs) per shelf without reinforcement.
The load-bearing capacity can be increased by about 50% by attaching additional wooden battens (e.g., 20x40 mm (3/4x1 1/2 inch) hardwood strips) to the underside of the shelf.
The 80 cm (31 1/2 inch) wide shelves with a depth of 28 cm (11 inch) have greater stability than deeper models because the load acts over shorter spans.
Wall fixing is strongly recommended to prevent tipping and lifting.
Alternatively, IKEA also offers the "Hemnes" model, which is partly more robustly constructed but has a different design.
Conclusion: A combination of 80 cm width, 28 cm depth, additional shelf reinforcement, and wall mounting is ideal for heavy books.
