ᐅ Which installation mistakes should definitely be avoided when assembling the Ikea PLATSA system?
Created on: 27 Oct 2023 13:23
adinmi59
adinmi59
27 Oct 2023 13:23
Hello everyone, I’m currently assembling my Ikea Platsa wardrobe and wanted to ask the community: What assembly mistakes should be definitely avoided to ensure the wardrobe is stable and secure afterward? I’m particularly interested in experiences with common issues such as incorrect alignment, improperly fastened connectors, or problems with how the individual modules fit together. Although I have the instructions, I’ve often read that there are some important details to watch out for with Platsa, so the furniture doesn’t end up wobbly or, in the worst case, tipping over. Are there any typical pitfalls you would warn about in advance? Thanks for your tips!
TRADI
27 Oct 2023 13:55
Hello adinmi59, your question is very well formulated, as the PLATSA series does require some attention during assembly. I’ll mention a few of the most common assembly mistakes that should definitely be avoided to ensure your cabinet doesn’t wobble or become unstable:
- Missing or loose dowels and connecting sleeves: These are often the main cause of later instability. It is important that they are fully inserted and tightly screwed in.
- Not carefully aligning the modules: PLATSA components must be precisely matched. Even slight deviations in alignment later cause wobbling or uneven gaps.
- Neglecting wall fastening: Especially with larger or taller PLATSA constructions, anchoring to the wall is essential to prevent tipping hazards.
- Screws not tightened correctly or enough: Many underestimate that PLATSA fasteners should be tightened as firmly as possible to ensure proper hold.
- Cover and side panels not mounted flush: This not only looks untidy but also weakens the stability of the structure.
If you keep these points in mind, you should be on the right track. If you have any questions about the exact procedure, I’m happy to help.
Elijah42
27 Oct 2023 14:21
The most important thing: Make sure you fasten the wall brackets properly. Without this, your PLATSA may hang slightly crooked or could tip over. Also, tighten the screws firmly, not just by hand.
TRADI
28 Oct 2023 08:12
Elijah42 schrieb:
Make sure to fasten the wall brackets securely.
Exactly, that can’t be emphasized enough. I’d like to add that when floors or walls are uneven, leveling with a spirit level before final screwing is essential. If you skip this step, you’ll end up with hinges that stick or doors that don’t close properly.
Another tip: when combining multiple PLATSA modules, ensure that the connecting fittings between the cabinets are installed correctly. If the elements aren’t properly joined, gaps will appear and the entire structure will be unstable.
In my experience, it also helps to dry-fit all components before actual assembly to check for fit. This way, you can spot errors early on before everything is screwed together.
bauku
28 Oct 2023 12:07
I find the PLATSA assembly really exciting! The key is to be patient and work carefully, step by step. A common mistake is skipping the assembly instructions and trying to put it together without following the steps. So: stay focused and follow the instructions exactly!
Also, make sure to place the base panels evenly to ensure a stable foundation later on 😊 The feeling when your cabinet stands rock solid is truly amazing!
One more bonus tip: if you’re building larger combinations, it’s better to work with a partner to handle the heavy modules more easily when adjusting them. Good assembly can be a lot of fun!
