ᐅ Where do you start when remodeling?
Created on: 18 Jul 2009 19:25
Dani99
Dani99
18 Jul 2009 19:25
we bought a cabin and plan to completely renovate it.
But what is the best order to do everything?
The sloped ceilings will be covered with drywall and then, together with the walls (partly), plastered again and finished with textured plaster.
The doors, including the frames, will be replaced, and the floor will be covered with country-style wooden flooring, except for the tiled rooms.
Thank you very much for your help.
Dani :-)
JOERG24
18 Jul 2009 20:32
Doors removed
Drywall
Plastering
Roughcast
(Painting)
Door frames
Flooring
Door leaves
Basically, always from top to bottom.
The door frames can also be installed earlier – it depends somewhat on the plaster and how you want to design the transition.
Dani99
19 Jul 2009 09:45
Hi,
thank you for your reply.
Doesn't using the door frames damage the plaster again?
Is there anything to consider regarding the width of the door frames when plastering?
Dani 🙂
JOERG24
20 Jul 2009 08:39
Normally, nothing gets damaged there.
The frame is inserted from the front and back into the recess and then covers the edge.
It depends a bit on the plaster or the texture.
Should the frame be embedded in the plaster, or should it later rest on the plaster surface?
Depending on the roughness and the desired appearance, the small gaps that form when installing can be filled with acrylic sealant before painting.
