ᐅ What type of lighting is suitable for Ikea PLATSA shelving units?
Created on: 10 May 2017 18:17
talipar
talipar
10 May 2017 18:17
Hello everyone, I am currently planning to equip my Ikea Platsa shelves with suitable lighting and am unsure which type of lighting would be best for this. Important factors for me are easy installation, pleasant light color, and sufficient brightness without glare or excessive heat. Does anyone know of suitable LED solutions that can be well integrated into or onto the shelves? Are there also any recommended mounting systems or power supplies that are compatible? Thanks in advance for your tips!
JAMESON
10 May 2017 19:03
For PLATSA, I recommend LED strips with warm white light. They are easy to stick on, have low heat output, and provide sufficient lighting. It is best to get the power supply and connector separately.
draleo
11 May 2017 08:46
For lighting Ikea PLATSA shelving units, LED strips are the best choice due to their flexibility and efficiency. It is important to choose a color temperature between 2700K and 3000K to create a warm and comfortable atmosphere. Additionally, the lighting should be dimmable to allow adjusting the brightness depending on the use. Installation is ideally done using 3M adhesive tape on the back of the shelves or with small clips if available. Power supplies with surge protection increase safety. Alternatively, there are specially integrable modules from third-party suppliers that are well rated on the market.
NICOLELIS
11 May 2017 10:12
Warm white LED strips are the best choice. They are small, flexible, and easy to install. Ideally, use a 12V power supply and, if possible, dimmable.
talipar
11 May 2017 13:29
Thank you for the tips so far. Are there any experiences or recommendations on how to neatly install the cables without negatively affecting the appearance of the PLATSA shelves? I’m especially interested in whether there are discreet channels or clips suitable for this purpose. Also, what about the power supply when multiple segments are to be illuminated? Is one power supply unit sufficient, or should multiple units be used?
barle
11 May 2017 16:01
talipar schrieb:
Are there any tips on how to neatly route the cables without negatively affecting the appearance of the PLATSA shelves?
It is best to run the cables behind the shelves; PLATSA often has small gaps or back panels where cables can be securely fixed with cable clips.
talipar schrieb:
What about the power supply when multiple segments are to be illuminated?
A powerful power supply is usually sufficient for several strips; it’s best to add up the wattage and then choose one with enough spare capacity.
