Hello everyone, I have a problem with my Billy shelf: some of the screw holes are torn out. The shelf is relatively new, but during assembly, I noticed that the screws can’t be tightened properly because the wood around the holes is already damaged. I’m wondering what I can do to repair the screw holes permanently and make the shelf stable again. Are there proven methods or suitable materials that work well? I’m not sure whether I should drill new holes in a different spot or use wood filler and similar products. Thanks for your advice!
Thank you for your helpful feedback!
One more question for clarification: When I use wooden dowels, do I need to screw the screw directly through the dowel? Or do you place the screw next to it, acting more like a nail, meaning in the wood outside the dowel?
Also, do you have any experience with whether the original Billy screws still work, or should I consider using different ones? I want to make sure the repair attempt doesn’t fail again immediately.
Good question!
Yes, exactly. You fill the old hole with a wooden dowel that fits perfectly. Then you drill a small pilot hole into the dowel (slightly smaller than the screw diameter) and screw the screw through the dowel into the shelf. This works because the dowel is firmer than the damaged particleboard.
Regarding the screws: The original BILLY screws are not bad, but sometimes wood screws with coarser threads are better, especially if you plan to assemble and disassemble the shelf frequently. They provide better grip in the repaired area.
FloZeke schrieb:
If I use wooden dowels, do I have to screw the screw through the dowel afterward?
One more addition: If you use wooden dowels or filler, make sure not to use a drill bit that is too small for the pilot hole. If the hole is too tight, the wood can split or the screw can cause the material to tear out further. When drilling the pilot hole, it is better to be cautious—drill a slightly larger hole and use a proper screw.
