I have an issue with my Ikea Besta cabinet where some of the screw holes are damaged. Specifically, the holes for the back panel fasteners and some of the connecting screws have either stripped or become too large, so the screws no longer hold firmly. This seems to happen quite often, especially when the furniture is assembled and disassembled or moved multiple times.
My specific question is: What practical and durable methods exist to repair damaged screw holes in Ikea Besta furniture so they hold securely again? I would like to know how to fix this without having to completely replace parts, what materials or techniques are recommended, and if anyone has personal experience with this.
I appreciate any advice on screw fillers, wood glue, alternative fastening methods, or replacement parts. Thanks in advance to everyone who can help!
Karljon schrieb:
My concern mainly involves the small cylindrical dowels and the metal screws that hold the cabinet together.The description is very helpful. For the connection with the cylindrical dowels, I recommend:
- First, fill any torn-out dowel holes with wood glue and fine sawdust. The sawdust should be very fine to create a tight bond.
- After it dries, lightly sand the area and insert new dowels.
For the metal screws on the back panel:
- Use wood filler for damaged holes, ideally a two-component wood putty. This provides long-lasting stability.
- Alternatively, metal screw-in anchors can be used; these are twisted into the wood hole and provide a new threaded hole for the screw.
Make sure the screws are not too long to avoid damaging the interior of the furniture. Also, avoid applying excessive force to prevent further splitting.
In general, it’s worth using quality products; although they are somewhat more expensive, they offer much greater durability in the long run compared to standard hardware store items.
