ᐅ What to do if Ikea Metod cabinet doors don’t close properly after installation?
Created on: 2 Apr 2019 08:07
U
Usneo
U
Usneo
2 Apr 2019 08:07
Hello everyone, I recently installed a kitchen with Ikea Metod cabinets, but some of the doors are not closing properly. Specifically, some doors either stay too far open or do not align flush with the cabinet frame. I followed the assembly instructions as precisely as possible, but even after multiple adjustments of the hinges, the issue remains. Does anyone have experience with reliably positioning Metod doors when there are closing problems? What steps are effective to avoid issues such as warping, misaligned doors, or uneven gaps? I would appreciate detailed tips, including suitable hinge adjustments or further inspection methods. Thank you in advance!
naudan
2 Apr 2019 09:15
Hello Usneo, I am familiar with your problem; this often happens with Metod doors. In general, the hinges should be precisely aligned, as they are adjustable in multiple directions. I would recommend three things: - First, check if the cabinet carcass itself is straight and plumb; otherwise, all adjustments will have limited effect. - Use the adjustment screws on the hinges: one for lateral adjustment, one for height adjustment, and one for depth adjustment. Lateral adjustment is often crucial to align the door flush. - Finally, check whether the doors are warped. Sometimes light repairs help, such as tightening the screws or replacing damaged hinges. If the doors still don’t close properly, the alignment of the soft-close dampers might also be a factor. Have you already checked the dampers?
FLONE41
2 Apr 2019 10:52
Hello Usneo, I can understand how frustrating it can be when the doors don’t close properly after installation. You put in a lot of effort, and yet something still doesn’t fit right. I had similar issues with my Metod kitchen. A small tip from my experience: sometimes it’s not just the hinges, but also the base or tiny unevenness that cause the doors not to sit correctly. I carefully checked the cabinet feet with a spirit level and adjusted them if necessary. It helped me to take it step by step and even remove a door completely to adjust it outside the cabinet frame before rehanging it. Maybe give that a try? All the best, and don’t get discouraged!
Eugeneki
2 Apr 2019 12:33
What is often overlooked is the correct positioning of the doors in relation to the cabinet frame. It is important to maintain precise clearances on all sides, as Metod is a modular system with fixed defined dimensional tolerances. Possible reasons for doors not closing properly include: - Irregularities in the cabinet’s base installation - Incorrectly adjusted or loose hinges - Warped or damaged doors - Incorrect assembly sequence I recommend first conducting a visual inspection of the cabinet frame and door panels, followed by systematically adjusting each hinge individually. In particular, adjusting the height—that is, modifying the hinges vertically—often leads to noticeable improvements in door alignment.
Roberta
2 Apr 2019 15:07
Adjusting doors correctly usually involves the screws on the hinges. Adjust the side and height screws until the door fits flush. If the door does not close, the issue may be the door stop buffer. Slightly realign the buffer. In cases of severe warping, only new doors can help.
gaubla
3 Apr 2019 07:24
This is an important point, as the dampers in Ikea Metod kitchens ensure the soft-closing mechanism and can actually hinder closing if they are misaligned. Additionally, I recommend checking the following:
- Inspect the cabinet carcass for any twists or uneven floors that might put stress on the doors.
- All screws on the hinges should be tight but not overtightened to allow smooth movement.
- For doors that sit very unevenly, it’s worth examining the hinge cups on both the door and carcass to ensure the holes are drilled correctly and evenly.
A systematic approach to adjustments will significantly improve functionality.
