ᐅ What tips do you have for a quick assembly of the IKEA Brimnes?
Created on: 2 Mar 2021 18:07
TORIN38Hello everyone,
I’m planning to assemble the IKEA Brimnes bedroom set soon and am looking for the most efficient tips to keep the assembly time as short as possible. Since the instructions seem quite detailed and there are several parts to put together, I’m curious if you have any specific methods, tools, or organizational tricks that have helped you complete the build quickly without mistakes.
I’m especially interested in whether you prefer or avoid certain steps to save time or even plan a step ahead.
What has been your experience with the material itself? Are there common pitfalls to watch out for that are better to know about early on?
I look forward to constructive answers that go beyond general advice and specifically relate to the Brimnes system.
Thanks in advance!
Thanks in advance!
For quick assembly of IKEA Brimnes, I recommend the following points:
- Preparation: Carefully check and sort all parts to immediately identify any missing components.
- Tools: A cordless drill with a suitable bit set significantly speeds up screwing compared to a manual screwdriver.
- Instructions: Read through the entire manual first instead of starting immediately. Understand where the larger modules should be assembled first.
- Batch assembly: When working with multiple identical cabinet parts, it is advisable to prepare them in parallel (e.g., assemble all shelves first).
- Helper: If possible, have a second person available to hold and align parts.
Common pitfalls are often the reflexes when aligning the back panels and correctly following the screw order to avoid warping.
Also, carefully pressing in the dowels is important to avoid damaging the material.
These steps ensure a fast and clean final assembly.
When assembling IKEA furniture, especially the Brimnes system, I follow a very structured approach and can offer some advanced tips beyond the standard recommendations:
- Work Surface: Use a large, flat table whenever possible so that parts don’t end up on the floor and get lost.
- Sorting: I sort small parts (screws, plastic caps, dowels) in multiple stages by type and size using small trays or compartment boxes to avoid mix-ups.
- Pre-Drilling & Dowels: Precision is crucial here. Always check the drilled holes before pressing in dowels to prevent jamming or breakage. The Brimnes system is notable for its connector bolts, which require appropriate torque but must not be overtightened to protect the material.
- Screw Sequence: I recommend fully assembling each module with all screws before attaching any lower or upper parts. This reduces material stress.
- Back Panels: These should be installed last and aligned very carefully, as they stabilize the entire piece. Approximate alignment can later cause warping and difficulties.
Common Pitfall: With Brimnes, pay special attention to the rollers for the drawers. They must be properly aligned, or the drawers will stick later on.
May I ask how experienced you generally are with furniture assembly? That could help me tailor more specific advice.
I assembled the Brimnes wardrobe last year – tip: patience pays off, even if you want to finish quickly.
Extra tip from me: make some good coffee or tea – never underestimate how helpful a short break at the right moment can be! 🙂
Be careful with the drawer slides too – they can easily get misaligned. If everything goes well, it will naturally fit better over time. Good luck with your project!
Lotizar schrieb:Absolutely right, that really helped me a lot.
A cordless drill with the right set of bits speeds up screwing a lot compared to using a manual screwdriver.
Laukau5 schrieb:I find that very interesting because everyone has different prior experience. I’m not a professional, but I always thoroughly read the instruction manual and tried to prepare everything in advance.
