ᐅ What tips are there if the wood splits with BILLY?
Created on: 1 Apr 2021 08:17
Lofila
Lofila
1 Apr 2021 08:17
Hello everyone, I recently assembled a BILLY bookshelf, but I noticed that the wood is splintering along some edges during assembly. This mainly happens where screws or dowels are inserted. I feel like I might be applying too much force when screwing, or the material might not be properly prepared.
Does anyone have specific tips on how to prevent wood splintering with BILLY shelves? I am particularly interested in whether it is advisable to pre-drill before screwing or if the screws should be inserted at a different angle. Any advice on suitable tools or alternative techniques would also be very helpful.
I want to avoid damage or aesthetic issues caused by incorrect assembly. Any experience-based suggestions are greatly appreciated – thank you in advance!
LOJOPAR
1 Apr 2021 11:43
Hello Lofila,
I can give you some targeted tips based on my experience with BILLY shelves to help with your issue of splitting.
1. Pre-drilling: This is actually the most important step. Most BILLY panels are made of particleboard with a thin decorative layer. If you screw directly in, the wood can slightly compress and cause splitting or surface tearing. Using a small drill bit (about 1-2 mm diameter (0.04-0.08 inches), depending on the screw size) can make a big difference.
2. Use a screwdriver: Ideally, use a cordless drill with a torque limiter. This prevents over-tightening and protects the surface. If you don’t have one, it’s better to screw by hand.
3. Angle & speed: Don’t screw in at an angle and avoid turning too fast. A clean, straight approach reduces stress on the material.
4. Wood protection: If the material is very dry, you can lightly coat the screws with wax or soap beforehand. This makes screwing easier and minimizes the risk of splitting.
5. Dowels & glue: If dowels are used, make sure the holes are the right size and not drilled too tightly. Sometimes lightly sanding the surfaces helps.
Summary: Pre-drilling and careful screwing are essential with BILLY shelves. Some home remedies like wax can also help. I hope this helps! If you want, I can also provide a detailed guide on how I assemble it.
paulu
1 Apr 2021 13:02
Pre-drilling is the most important step. Insert screws slowly and straight. Use a screwdriver with a torque limiter or turn by hand.
kulau
2 Apr 2021 09:27
In addition to the previous recommendations, I would like to go into a bit more detail because the issue of "wood splintering with BILLY" is often underestimated.
First of all: The "wood" used in BILLY is not solid wood but a thin chipboard or MDF panel with a decorative foil, which is quite delicate. This means the material is structurally weaker than solid wood and therefore more prone to splintering. Screwing creates stress in the material, which usually releases along the edges and surfaces.
LOJOPAR schrieb:
A small drill bit (about 1–2 mm diameter, depending on the screw size) can work wonders here.
I can only confirm that. It’s important to pre-drill especially where the screw is close to the edge, as that is where the largest cracks usually occur. Additionally, before pre-drilling, make sure the drill bit is sharp to avoid unnecessary chipping.
Furthermore, you should consider the following:
- Use screws with finer threads that are specifically suitable for chipboard.
- When inserting the screw, avoid over-tightening the surface with the screw head – it can help to tighten the screw with less force initially and then finish the rest by hand.
- If possible, use plastic washers to reduce stress on the surface.
I’m also curious: Are the screws always in the same spots, for example edges or pre-drilled holes, or does the splintering occur all over the shelf? This would be important to determine whether it is a general assembly issue or a material defect.
I hope these details help you and I look forward to your feedback.
