ᐅ What is the best way to install BILLY shelves in basement rooms?
Created on: 24 Jan 2020 08:12
lisan
Hello everyone, I am currently planning to install several Billy shelves in my basement and am looking for the best mounting options. The basement walls are partly slightly damp, and the floor is made of concrete. I don’t just want to place the shelves there; I want to secure them properly so they stand firmly and don’t tip over. I am also interested in which fastening materials work best for different wall surfaces like plaster, concrete, or sometimes slightly crumbly substrates. How do you handle this in basement rooms? Are there any special tips for preparation or moisture protection measures? I look forward to your experiences and advice!
Luciandi
24 Jan 2020 11:37
I can only confirm these statements. What has often helped me is installing a slight backward tilt of 1-2° (degrees) on the shelf, meaning the shelf leans slightly towards the wall. This reduces the tipping force on the wall fixings.
Additionally, I always use combinations of metal brackets and screws anchored into the wall. Plastic anchors have failed for me in damp and cool basements due to environmental conditions—they tend to loosen over time.
Edric schrieb:
remove loose plaster
You should definitely do this; otherwise, the anchor won’t hold properly.
Guyju
24 Jan 2020 12:15
A small tip regarding anchors: There are anchors specifically designed for challenging substrates like crumbling plaster or solid brick, known as “frame anchors” or “heavy-duty anchors.” These expand more and provide better holding power because they secure not only against tension but also against compression.
Important: Always select a drill bit slightly larger than the anchor diameter before installation to ensure the anchor fits properly—not too loose and not too tight. Also, pay attention to the drill hole depth—usually, a standard anchor length of 50mm (2 inches) is sufficient for Billy-type shelves.
lisan schrieb:
Or would corner braces, which you screw to the wall and the shelf, be enough?
Yes, that is absolutely sufficient and the right approach; securely fixing the shelves is essential.
bujufa
25 Jan 2020 07:59
One additional note on moisture: Even if the walls appear only slightly damp, it is advisable to use silicate-based coatings or moisture-regulating wall paints, especially behind shelves. This can help minimize trapped moisture.
If sealing is possible, a moisture barrier against rising damp should be installed before assembly.
Also, thin feet made of plastic or rubber can be placed between the floor and the shelf legs to prevent direct contact with potentially damp flooring.
DAMALO
25 Jan 2020 09:48
Guyju schrieb:
Important: When drilling, always choose a drill bit slightly larger than the plug diameter to properly insert the anchor
I neglected this during my first installations and later realized that the anchors did not secure properly. It’s very frustrating and time-consuming to redo everything. It’s better to be precise and pre-drill with a drill bit that matches the anchor size.
In my experience, it’s also important to always screw the shelves to the wall before loading them. Otherwise, shifting can cause issues over time, and tipping can happen quickly.
Celia
25 Jan 2020 10:12
Shelving in the basement should always be securely fixed to the wall.
Use metal anchors for concrete walls.
Remove crumbling plaster, otherwise the wall plug will not hold.
Jodyro
25 Jan 2020 13:07
I have secured BILLY shelves in the basement using frame anchors, and this works very well. The shelves do not tip over and are very stable. It is important to measure carefully before installation and to use a spirit level.
