I am planning to transport several IKEA Brimnes furniture pieces soon and would appreciate some practical tips. The furniture items are quite large and relatively heavy, and some are already disassembled. My main concern is how to best secure and transport the individual parts to avoid any damage. I am also interested in experiences regarding transport in a private car versus renting a van or using a professional moving company.
Does anyone have specific recommendations for preparation, packaging materials, and optimal loading? Are there any particular challenges to consider with the Brimnes series design? I look forward to your advice and any experiences you’ve had with moving or furniture purchases.
Thanks in advance!
Thanks in advance!
Hello gaupo,
For transporting IKEA Brimnes furniture, I recommend the following points:
- If the furniture can be disassembled, take it apart as much as possible. This reduces the risk of damage.
- Protect sensitive surfaces with blankets or bubble wrap. The white surfaces, in particular, are easily scratched.
- Use strong ratchet straps to secure individual parts inside the vehicle to prevent shifting.
- When transporting in a car, try to lay the furniture flat to keep the center of gravity low.
- If possible, use loading aids such as a hand truck or furniture dolly.
Keep in mind that some Brimnes pieces have thin back panels, which can break if placed directly on hard surfaces. Always use padding in between.
Interesting question.
However, I think it is important to consider whether it is truly necessary to completely disassemble the furniture. Often, excessive dismantling and reassembling cause more problems than benefits—such as when fasteners loosen or get damaged over time.
This point is only partially correct. I recommend disassembling only large, difficult-to-handle furniture pieces. Otherwise, it is better to secure and cushion them well.
Also, you should check whether the transport route is large enough to move the furniture piece as a whole before deciding to disassemble it.
Regarding surface protection, bubble wrap is indeed useful, but the environmental impact should not be overlooked. Reusable blankets are more sustainable.
Overall, I believe it is important to plan transportation not only from a practical but also from an ecological perspective.
kieran schrieb:
If the furniture can be taken apart, try to disassemble it. This reduces the risk of damage.
Hello gaupo,
I had similar furniture last year and can share some experience with you:
- Make sure to keep all screws, dowels, and small parts in clearly labeled bags when disassembling, so nothing goes missing during reassembly.
- To prevent damage, kitchen towels or old T-shirts can be used as padding if bubble wrap is not available.
- Transport the furniture on a flat surface to avoid tipping or falling over.
- If using small cars or vans, be sure the furniture is well secured to prevent movement during the journey.
If you keep these points in mind, the transport should go smoothly. If you have any questions during assembly, I’m happy to help.
Hey gaupo,
The Brimnes transport really challenged me as well! My advice: stack everything smartly and use cushions or something similar as padding in between. This way, you avoid the boards rubbing against each other, which can cause ugly scratches later on.
Exactly! You don’t always need professional materials—what you have at home often works just fine. And remember: saving a little time while loading isn’t worth it if you end up damaging the furniture. Better to take it slow and steady than to be quick and shaky.
PS: If you can take the cabinet doors off, definitely do that—it saves space and weight when carrying. Good luck!
Ethan schrieb:
To prevent damage, kitchen towels or old T-shirts make good padding if bubble wrap isn’t available.
