ᐅ What type of burglary protection do you have? And what is the estimated cost?
Created on: 30 Oct 2016 13:14
Mizit
This topic might not be exactly right here since we are not building new but buying, but it also relates to planning and idea development.
We are buying a house from 1995. The front door has a multi-point lock, and the basement has a fireproof security door, which probably can’t be opened quickly when locked. That’s all.
Due to a personal incident related to burglary, I am currently somewhat more sensitive to this issue. I am often alone with the children, and the house is in a remote location, with open fields behind us. Although the area is mostly rural and, according to the owner, there have been no incidents in the village so far, I don’t want to rely on that. In short: we want to allocate part of our budget to security investments.
We will schedule an appointment with the local police to get advice.
Regarding the front door: a multi-point lock sounds good – is that enough initially?
Next to the front door there is a glass panel, double-glazed, without a window handle. This could probably be broken quickly, but because of the muntins, it is probably not possible to enter the house quickly this way. We are considering installing a glass break film on the inside. Possibly combined with an acoustic alarm if someone tries to strike the glass?
The main issue is definitely the numerous windows, especially at the back of the house. None of these are visible from the street. As mentioned, the windows are double-glazed from 1995. There are no mushroom head locks installed. We couldn’t find a clear cost estimate for retrofitting such mushroom head locks. Can you share any insights? Possibly that alone would be so expensive that it might be more worthwhile to replace the windows? However, I think that would likely exceed our budget given the number of windows…
While researching mushroom locks, we came across these EM3 locks, which cost about 60 euros each. Do you have any experience with these, and can they be a practical alternative to mushroom head locks?
Regarding alarm systems, there are all kinds available. Mechanical security should probably take priority over acoustic alarms, right? Personally, although my husband sees it differently, I don’t really believe these alarm systems are that effective. Anyone planning a professional break-in, possibly after some reconnaissance, will know in such a rural location that the police won’t arrive in two minutes and neighbors probably won’t be outside immediately either. And what good would it do us if the alarm goes off while we’re sleeping? Acoustic alarms certainly aren’t bad, but depending on the price, I question whether the cost-benefit ratio is reasonable. Probably it would need to be that various alarms are also visible in a way that hopefully has a deterrent effect? Motion detectors, cameras, or even a connection to a security service?
How have you approached this topic?
World-e schrieb:
I don’t think burglars are deterred by that. Some might even think there’s something worth stealing if cameras are installed.Is that your assumption or is it proven?
Bieber08153 Nov 2016 21:59Nafetsm schrieb:
Is that your assumption or can it be proven? It is proven that video surveillance does not prevent crimes. It is also widely known that the police always recommend starting with more passive protection measures first, such as windows and doors.
77.willo schrieb:
At an event in Berlin, the state criminal police regarded video surveillance, alarm systems, and dogs as ineffective—at least as protection against burglaries, though they may contribute to the family’s sense of security. A similar view was expressed during a police presentation at a real estate fair in Osnabrück. The main recommendation was to first invest in mechanical security for vulnerable points (windows and doors, especially those that are not visible from the outside). Of course, attention should also be paid to other measures that do not necessarily cost anything (such as not leaving ladders in the garden, removing climbing aids, making the property visible, and maintaining mutual vigilance within the neighborhood).
Additionally, I followed the advice to install lighting (motion sensors with LED lights around the house). This can act as a deterrent, especially if the intruder faces the risk that neighbors might notice something—that is, windows within view that allow for observation.
FrankH schrieb:
I have secured the pull-down staircase by locking it from the top.How did you solve that? I have been thinking about it too.
sirhc schrieb:
How did you solve that? I’ve been thinking about it too. At the moment, I’ve just placed a tension rod underneath (usually used to hold drywall sheets in place so they can be screwed in), but I’m still looking for a better long-term solution. It doesn’t bother me much in the hallway corner for now, but it’s definitely not very attractive. I also considered a sliding bolt or something similar, but it’s difficult to reach up there close to the ceiling. Plus, it would need to be anchored securely enough to withstand pressure when someone applies their full body weight on top.
