ᐅ What common issues arise during the transportation of IKEA Hemnes furniture?
Created on: 25 Feb 2022 09:37
hilalkaHello everyone,
During my previous transports of IKEA Hemnes furniture, I have noticed recurring specific issues that unnecessarily delay or complicate the process. I am particularly interested in which common difficulties other users have experienced when transporting Hemnes furniture. I am not only referring to obvious challenges such as the packaging volume but also aspects like the sensitivity of the material surface, the fit of individual components after transport, as well as possible damage caused by improper handling or transport methods. Are there reliable tips on how to avoid these issues during loading or transportation? What about the stability of the packaging, especially for larger parts? I look forward to detailed answers so I can better plan my upcoming transports.
sarGabriel25 Feb 2022 10:03The biggest challenge when transporting Hemnes is often the size and weight of the packages.
- Some parts are bulky and heavy.
- Be careful with scratches, as the surfaces are delicate.
It is best to use padding and blankets during loading to prevent damage.
The following issues frequently occur during the transport of the IKEA Hemnes series:
- The MDF and solid wood components are durable, but the painted surfaces are prone to scratches and dents if transported without adequate protection.
- Larger parts, such as cabinet doors or bed panels, are bulky and can be difficult to fit securely in a vehicle, leading to movement during transit and increasing the risk of damage.
- The packaging is often not designed for long or uneven transport routes, which can cause the boxes to tear or break open.
- Another concern is that the included screws and fittings are sometimes not securely fastened, increasing the risk of loss.
Recommendations:
- Use moving blankets or other protective materials.
- Check the packages before departure to ensure they are securely packed and reinforce them if necessary.
I agree; size and weight are important factors.
Recommendations:
sarGabriel schrieb:
The biggest problem when transporting Hemnes is often the size and weight of the packages.
Alberto5126 Feb 2022 07:18I fully understand the frustration that can arise during some transports. For example, with the Hemnes, I once had a cabinet door open during the trip. This made me very uneasy because I had carefully padded everything. The uncertainty about potential damage is what weighs on me the most.
This matches my experience exactly. My advice is to really secure these bulky parts firmly with straps, rather than just storing them loosely. Protective padding helps a lot with this. Also, if possible, it’s better to store the parts angled or vertically in the vehicle to prevent them from damaging each other.
Who else has had similar experiences?
SUBEN60 schrieb:
Larger components like cabinet doors or bed sides are very bulky and cause problems when loading into the vehicle, which can lead to unwanted movement during transport
In addition to the points already mentioned, I would like to address the often underestimated issue of load distribution in the transport vehicle.
Hemnes furniture usually consists of larger and heavier wooden components. If these are stacked unevenly or too heavily in one spot, deformation or even breakage can occur during transport, especially with furniture made from fiberboard. The weight on the lower boxes should also be well distributed to avoid crushing.
Furthermore, sturdy ratchet strap systems are recommended to securely fasten the furniture. On longer journeys, regular checks of the load are necessary to prevent shifting early on.
Finally, a tip: if possible, avoid fully assembling all parts before transport, since individual components are easier to store flexibly and the risk of transport damage is reduced.
This is an important point that I can clearly confirm.
Alberto51 schrieb:
That matches my experience exactly. My advice is to really tightly secure such bulky parts with straps and not just store them loosely.
