ᐅ What size should interior doors be? 90 cm or 100 cm width / 211 cm height?
Created on: 13 Apr 2018 08:56
blaupuma
Hello, our house planning is steadily progressing, and now I am deciding on the dimensions of the interior doors.
I am torn between 90 or 100 cm (35 or 39 inches) width / 211 cm (83 inches) height for the interior doors.
We have a ceiling height of 265 cm (104 inches).
The extra cost for the wider doors is minimal. I actually see only advantages with the wider doors, except that sometimes they can look like hospital doors :-(
The country-style design changes that only slightly.
Has anyone chosen this and regretted it?
Thanks
blaupuma13 Apr 2018 11:36
A 90 cm (35 inch) door is sufficient for a wheelchair.
Sometimes an even narrower one will do.
Maria16
13 Apr 2018 12:30
A standard wheelchair can pass through 76cm (30 inches) wide doors with some effort. However, this is not officially considered accessible, and the doors will most likely get scratched over time. Depending on the wheelchair user, even 1m (39 inches) wide doors may eventually show scratches.
An electric wheelchair, on the other hand, will likely be difficult or impossible to use without at least 1m (39 inches) wide doors.
hemali2003
13 Apr 2018 13:25
We have 1 meter (3 ft 3 in) doors in the utility room and living room, and I think the rest are 83 cm (33 in).
The 1 meter (3 ft 3 in) doors already feel spacious when opened – I really like that about the living room door. They’re also practical for carrying boxes, laundry baskets, and chairs through.
However, when closed, they do look quite bulky... Large doors naturally require a lot of space to open.
If you don’t have a practical reason for larger doors, feel free to go with 90 cm (35 in).
wrobel13 Apr 2018 19:39
Hello
We have doors measuring 100 x 225 cm (39 x 89 inches) throughout the entire house. Only the guest bathroom and the stove room have narrower doors installed. The ceiling heights increase from 250 to 340 cm (98 to 134 inches).
If the proportions and the floor plan are right, it already looks good.
Olli
haydee
13 Apr 2018 20:17
Doors that are 75 cm (30 inches) wide only work with a medical wheelchair, which are narrower and prone to damage.
90 cm (35 inches) doors work quite well for walkers and wheelchairs, but electric wheelchairs can cause damage.
100 cm (40 inches) doors are comfortable.
We have 100 cm (40 inches) wide doors.
Planning wider doors because of a potential disability is pointless if everything else doesn’t fit.
11ant13 Apr 2018 21:04
blaupuma schrieb:
The additional cost for the wider doors is minimal. I actually see only advantages with the wider doors, except that sometimes they look like hospital doors :-(
The country house style only changes that slightly.
Country house style? – I thought you were leaning toward Scandinavian architecture?
What motivates you not to simply choose standard sizes (rough opening 87.5 cm (35 inches) for living and bedrooms, also 75 cm (30 inches) for bathrooms, possibly 62.5 cm (25 inches) for storage rooms)?
A height of 212.5 cm (84 inches) seems normal to me nowadays; a height of 200 cm (79 inches) looks a bit squat for room doors at 1 meter (39 inches) wide.
