ᐅ What size should interior doors be? 90 cm or 100 cm width / 211 cm height?
Created on: 13 Apr 2018 08:56
blaupuma
Hello, our house planning is steadily progressing, and now I am deciding on the dimensions of the interior doors.
I am torn between 90 or 100 cm (35 or 39 inches) width / 211 cm (83 inches) height for the interior doors.
We have a ceiling height of 265 cm (104 inches).
The extra cost for the wider doors is minimal. I actually see only advantages with the wider doors, except that sometimes they can look like hospital doors :-(
The country-style design changes that only slightly.
Has anyone chosen this and regretted it?
Thanks
Thanks
I believe this is less about needing and more about wanting.
And to a large extent, it’s a matter of proportions.
In a house with 70m2 (750 sq ft) of living space on the ground floor and a finished attic, such large doors simply don’t fit, regardless of whether I am 2m (6 ft 7 in) tall or weigh 150 kg (330 lbs).
Olli
Olli
As a management consultant, I usually consider myself quite knowledgeable in the field, and just over ten years ago, I was closer to 150 kg than to 2 m (6 ft 7 in).
From an economic perspective, the answer is clear: 213 cm (7 ft) is a height that is currently trending (and therefore increasingly a standard stock size and b. competitively priced), while 226 cm (7 ft 5 in) remains a custom order dimension.
If @Christian NW is only asking about personal preference, I assume none of the residents is exceptionally tall. Without motivation related to body height, there is still a reference point to consider: the lintel height of the windows.
I would want to avoid the impression—warning, perspective distortion!—that the windows appear to be “wearing their hats pulled down too low” when comparing the relation between door lintel height and window lintel height.
My conclusion—as a former building components manufacturer without special expertise in interior doors—is a clear recommendation for the 213 cm (7 ft) door height. Even @blaupuma “can manage with this,” and he has rooms with open gables.
