I am planning to get an Ikea Pax shelving unit and would like to know as precisely as possible the maximum load capacity of the individual shelves and the unit as a whole. I am particularly interested in how much weight a single shelf can hold without sagging or being damaged. Equally important is the total load capacity—how much weight can be safely stored across all levels combined. Also relevant are any differences depending on the material variant (e.g., wood fiberboard vs. metal frame) or additional reinforcements that Ikea may recommend or offer. I hope someone here has experience or reliable information to help me make a decision. After all, overloading a Pax unit can quickly lead to stability issues—and I want to avoid that.
The shelves of a Pax wardrobe typically support about 25 kg (55 lbs) each. The total load capacity is approximately 70 to 100 kg (154 to 220 lbs), depending on the construction and wall mounting. It is important to always secure the wardrobe to the wall; otherwise, the load capacity decreases significantly.
In general, the load specifications at Ikea are calculated quite conservatively to ensure safety and durability. For the Pax system, each individual shelf made of wood fiberboard is typically rated to hold 25 kg (55 lbs), provided the load is evenly distributed. One important aspect to pay attention to is that the shelf is correctly assembled and that all connectors are properly installed. This reduces the risk of bending or failure.
The maximum total load also depends greatly on the type of mounting. Without wall attachment, stability can decrease rapidly. With proper wall fixing, the load capacity of the entire shelf can reach 100 kg (220 lbs) or more—this refers to the combined weight of all shelves and the structure.
Regarding materials, the standard shelves are mostly made from wood fiberboard, which has limited elasticity. Metal frames or reinforcements are not included in the Pax system, but there are accessories such as additional strips or supports that can improve load-bearing performance.
An important question is what you mainly intend to use your shelf for: books, clothing, or heavier items? Depending on this, it is advisable to distribute the load more evenly and especially to store heavier items at the bottom to minimize the risk of tipping.
For additional clarification:
- A single shelf panel in the Ikea Pax system is rated by the manufacturer for a maximum recommended load of about 25 kg (55 lbs). This assumes an even distribution of weight to avoid localized overloading.
- The overall load capacity of the shelving unit depends greatly on the wall mounting. Without secure fastening, stability issues or even tipping can occur. Fastening methods differ in load-bearing capacity depending on whether they are attached to drywall or concrete walls.
- The load capacity of all installed components adds up in theory but is influenced in practice by the quality of assembly and material aging.
- Additional reinforcement, such as cross braces or using more robust shelves, is not part of the Ikea Pax system by default but can be done as a DIY modification.
Therefore, the realistic total load capacity of the shelving unit is usually between 70 and 100 kg (154 and 220 lbs) with proper assembly and mounting. It is recommended to follow Ikea’s assembly instructions carefully and regularly check the fastenings.
islaron schrieb:
The shelves of a Pax closet usually support about 25 kg (55 lbs).Thanks, that's already a good starting point.
PLOMA schrieb:
One important question would be what you mainly want to use your shelving unit for? Books, clothes, or heavier items?The shelf will mainly be used for storing books and some binders. Additionally, a few decorative items and occasionally some heavier electronic devices, like a small amplifier. So the load distribution is probably uneven – books on the lower shelves, binders and decorations more on top.
Regarding wall attachment: I’ve always thought this was only a safety measure against tipping, but you’re saying it also improves load capacity. Can someone explain in more detail how fastening the unit to the wall affects its weight-bearing capability?
And last but not least: Does Ikea provide any measurements or recommendations for when shelf reinforcement is necessary? Or when it would be better to choose a different shelving system?
Gaonle schrieb:
Regarding wall mounting: I always thought it was only a safety measure to prevent tipping, but you say it also improves load capacity.That is correct. Wall mounting greatly stabilizes the overall system. In practice, fixing the structure secures the shelf against tipping movements and shear forces. Without wall mounting, the loads on the shelf board and the construction can create leverage forces that overload both the shelves and the connections. Anchoring the unit to the wall also provides lateral fixation.
From a technical perspective, this increases the possible load because the shelf works less and the forces are better distributed.
Gaonle schrieb:
Are there any dimensions or recommendations from Ikea about when shelf reinforcement is necessary?Ikea itself does not provide explicit reinforcement recommendations, as the system is designed for its intended load range. However, if loads regularly exceed 25 kg (55 lbs) per shelf or especially heavy items are stored, additional load reinforcement is advisable, for example by adding a metal profile on top or a support in the middle of the shelf.
In summary, the Pax shelving system is well suited for moderate loads, but for very heavy loads, a more specialized shelving unit should be considered.
