Hello everyone, I would like to start a discussion about the best ways to clean Malm surfaces without damaging them or leaving unsightly residues. This specifically concerns the light oak wood with its characteristic matte, slightly porous surface. I have noticed that conventional cleaning agents sometimes cause streaks or spots. Some recommend special furniture cleaners or natural products, while others swear by home remedies. What are your experiences? Which cleaning methods really work best, especially to preserve the natural look and feel? Which products or techniques should be avoided? Thanks for your tips!
Regarding dust and cleaning, I would like to add that the finish on this piece of furniture provides some level of protection but can be damaged by improper cleaning. Besides the usual method of using a damp microfiber cloth, I recommend avoiding any harsh cleaning agents containing alcohol, ammonia, or similar substances. Ammonia, in particular, is a common ingredient in cleaners and can damage and visibly alter the matte surface. It is also advisable not to use abrasive cleaners or rough sponges, as they can scratch the coating. Depending on the degree of dirt, a mild all-purpose cleaner without solvents, used sparingly, can achieve better cleaning results. For grease stains, a small amount of mild dishwashing detergent solution often helps. After cleaning, the surface should be wiped with a soft, dry cloth to prevent it from becoming too wet. The water temperature is also important: lukewarm water is ideal, while hot water can affect the finish.
kibutar schrieb:
If stains are stubborn, you might need to use a specialist cleaner for matte lacquered wood, preferably testing it first on a hidden area. Thank you, that sounds very helpful. I actually have a few small water stains on a door that I can’t completely remove. Could you recommend a specific specialist cleaner that you use or know of? It would also be interesting to know how careful you need to be with matte lacquered oak to avoid the finish becoming cloudy or dull.
sau64 schrieb:
Can you recommend a specific specialty cleaner I often use products from Osmo, which are specially designed for oiled and lacquered wood surfaces. The Osmo Care Oil range also includes cleaning products that are gentle and do not damage the surface. It is important to apply them sparingly and follow the instructions carefully. Especially with matte lacquered surfaces, using too much product can easily cause buildup or shiny spots. For water stains, gently rubbing with a soft, almost dry cloth often helps; sometimes the mechanical action alone without chemicals is sufficient.
