ᐅ What is the best way to clean Malm surfaces?
Created on: 3 Sep 2021 08:13
sau64
Hello everyone, I would like to start a discussion about the best ways to clean Malm surfaces without damaging them or leaving unsightly residues. This specifically concerns the light oak wood with its characteristic matte, slightly porous surface. I have noticed that conventional cleaning agents sometimes cause streaks or spots. Some recommend special furniture cleaners or natural products, while others swear by home remedies. What are your experiences? Which cleaning methods really work best, especially to preserve the natural look and feel? Which products or techniques should be avoided? Thanks for your tips!
V
vincent46
5 Sep 2021 07:49
I am also curious about how often you clean your Malm furniture. For me, it varies, but I try to dust at least once a week and do a more thorough damp cleaning once a month. How about you?
kibutar
5 Sep 2021 08:33
vincent46 schrieb:
How often do you clean your Malm furniture?
With sensitive matte surfaces, this is a good question because cleaning too often with moisture can damage the coating over time. My recommendation: dust regularly, preferably daily or every few days, using a dry cloth. Only clean with moisture if there is actual dirt—otherwise, dry wiping is sufficient. In professional settings, care is usually more preventative and gentle, rather than constantly using water and cleaners. So, less contact with the material and more maintenance through dry cleaning.
sau64
5 Sep 2021 10:14
kibutar schrieb:
Dust regularly, damp cleaning only when necessary
Thank you, these are very practical tips. I will approach it accordingly. It is also important for me to maintain the natural matte appearance and to only slightly moisten the cloths. I suspect that in case of error with the alcohol-based cleaner, I will simply have to temporarily even out the surface, perhaps using Lorena’s tip with polish or treatment oil.
lorena
5 Sep 2021 10:45
sau64 schrieb:
Temporarily leveling the surface with maintenance oil
Yes, that can help. But be careful with the amount. Use just a light touch of oil and avoid rubbing it in too strongly, otherwise the surface may become blotchy or shiny. It's better to apply several very thin layers rather than one thick one.
