ᐅ What can be done about dented edges on Billy bookcases?
Created on: 6 Aug 2022 08:43
Marfo
Marfo
6 Aug 2022 08:43
I have noticed some dents along the edges of a few of my Billy shelves, which seem to have been caused by rough handling or pressure. Especially on the front edges of the shelves, there are small dents or slightly pressed-in spots, which affect the overall appearance and raise concerns about potential structural weakness.
I am interested in what methods have proven effective for repairing these dented edges or preventing them from getting worse. Are there any special tools, household remedies, or perhaps techniques from furniture making that you would recommend?
It would also be helpful to know if treating the surface afterward is advisable to avoid unnecessary damage or yellowing, for example, when using heat or moisture to work on the edges.
Looking forward to your experiences and advice!
Fitigu
6 Aug 2022 10:21
To fix dented edges on Billy shelves, a combination of gentle heat application and careful pressing is recommended.
The shelves are mostly made of particleboard with a melamine coating, so it is crucial to proceed cautiously to avoid damaging the surface. One method is to place a damp cloth over the dented area and then carefully apply a low-temperature iron. The moisture in the wood fibers can expand, often slightly reducing the dent.
Warning: Keep the temperature low to avoid damaging the melamine surface. Any further treatment can be done with fine sandpaper (grit 240 or finer), but only very lightly and only on non-visible areas.
Additionally, I recommend protecting dented edges mechanically by applying edge protection strips (e.g., self-adhesive plastic or metal profiles) to prevent further damage.
edisonbla
6 Aug 2022 11:37
Hi Marfo,
I had the same problem with my Billy shelves and solved it like this: I lightly covered the damaged area with a damp cloth and then gently warmed it from behind using the back of a hot kettle (without applying much pressure!). The heat and moisture give the wood fibers a little boost, and this worked surprisingly well for me.
[quote=Fitigu, post: j8b9h2, member: XXX]The method with a damp cloth and iron sounds like a similar approach—just cooler if you don’t have an iron nearby 🙂]
The important thing is not to get the area too hot and definitely not to heat it for too long; otherwise, you risk causing more damage than good. Afterward, treat the edges with a scratch-resistant varnish or wood oil to protect the surface.
It sounds simple, but it worked reliably for me. Give it a try!
rimole
6 Aug 2022 14:14
In addition to heating, it often helps to gently shape the edge with your fingers or a soft wooden tool. Afterwards, wipe the surface and let it dry.
If the board is completely warped, replacement is the only solution. For small dents, the effort is usually worthwhile.
Jeanbar
7 Aug 2022 09:08
Hello Marfo,
your question addresses a common issue. I would like to add that the material of the Billy shelves is very sensitive to moisture. The method using a damp cloth and heat can be useful, but it should really be applied only sparingly.
Another option is to use wood filler for deeper edges. This can be sanded very finely and then refinished with a suitable varnish. Make sure the filler is suitable for particleboard.
It is important to apply a protective layer after the repair to shield the furniture from future mechanical stress and moisture exposure. A clear furniture wax or a special plastic varnish works well.
If you have experience with wood preservatives, please feel free to share your impressions – maybe we can recommend the best products for Billy shelves.
