ᐅ What are some clever modification ideas for the IKEA Brimnes wardrobe?
Created on: 11 Dec 2019 19:07
U
usleelHello everyone, I’m looking for creative and practical ideas on how to modify the IKEA Brimnes wardrobe to make it more functional or personalized. The wardrobe is quite simple and often a space saver in small apartments, but I believe with some adjustments or conversions, it can be made even better. Does anyone have experience with optimizing the interior space, enhancing its appearance, or combining it with other furniture? I’m especially interested in tips that can be done with manageable effort without compromising stability. I would appreciate it if you could share your best hacks or modification suggestions!
I totally understand what you mean – the Brimnes is really a basic staple, but it often feels a bit too ordinary. For me, it’s important that such a hack is not only practical but also has a personal touch; otherwise, it’s just not enjoyable.
What helped me was adding extra removable small shelves inside, which I can just place in to keep things organized. Sometimes I also experiment with clip-on rails on the inside of the doors for small items like keys or jewelry – especially when space is limited, this creates a lot of additional storage.
The only tricky part was precisely adjusting the dimensions because the door width at IKEA doesn’t always match standard accessories perfectly. Maybe you could already consider whether you need special adapters or custom-made holders? I’d also like to know how exactly you plan to use the cabinet – as storage, a media unit, or something else?
The approach of modifying the Brimnes wardrobe really opens up many possibilities if you take some time for planning and precise execution. First, it is important to take exact measurements and consider which materials to use. Wood panels from a hardware store work well here, but you need to know the exact screw positions to avoid compromising the original stability.
A practical example:
- Divide the interior space with custom-fit shelves at different heights to create more organization without much effort.
- Small magnetic strips or hooks can be attached to the inner doors, either screwed in or fixed with strong adhesive tape—very useful for tools or small items.
- For a visual upgrade, I built a projector box to transform the wardrobe into a media center. Ventilation slots and cable channels need to be taken into account during this.
Regarding the method, I recommend always pre-drilling all holes and paying attention to edge protection. If major modifications are planned, please give feedback so I can provide more precise advice on screw positions and load-bearing capacities.
There are some established methods to improve the Brimnes wardrobe:
- Organize the interior efficiently: Adding extra shelves made of 16mm (5/8 inch) MDF provides stability and better space utilization.
- Install drawer inserts or baskets to keep small items separated and easily accessible.
- The back panel can be replaced with a thin but sturdy plywood board for increased stability, especially if the original thin back panel is considered a weak point.
- For more personalization, the surface can be treated with films or paints, but proper priming must be observed to minimize wear.
Please be cautious when making modifications that involve screwing and altering the structure, as the wardrobe is primarily designed for load-bearing through its shape and frame. For major changes, I recommend consulting a carpenter or at least having detailed plans.
