ᐅ What experiences have you had using Ikea PLATSA shelving units as room dividers?
Created on: 17 May 2023 10:23
O
onatsau
O
onatsau
17 May 2023 10:23
I am considering using Ikea Platsa shelves as room dividers in my apartment and wanted to ask the community: What experiences do you have with Ikea Platsa shelves used as room dividers? I am particularly interested in how stable the constructions are, whether the shelves work well in different room sizes, and how flexible they are visually.
I am a bit concerned that the units might be too light or wobbly when placed freestanding as room dividers, especially without additional wall anchoring. Also, I would like to know how practical the assembly is, especially if you are not an experienced DIYer.
Do you have any tips or specific configurations you would recommend? I would really appreciate hearing about your experiences!
Nakar33
17 May 2023 12:45
Hello @onatsau,
Regarding your question about using Ikea PLATSA units as room dividers, I can share some insights from my personal experience.
First, about stability: The individual modules are generally stable as long as they are assembled sensibly. However, PLATSA is primarily designed as a modular system meant to be fixed to a wall or placed in room corners. If you plan to use the units freestanding as room dividers, it’s worth considering additional anchoring, especially for taller constructions.
- Tip 1: Use the corner connectors that Ikea provides to screw the modules together. This greatly increases overall stability.
- Tip 2: If you don’t want to fix them to a wall, you might consider building a narrow base plate or plinth to set the units on, which improves their standing support.
About assembly: PLATSA is generally easy to put together, and Ikea provides very detailed instructions. A longer screwdriver or cordless drill is recommended because some connections require driving screws deep in. Having the right tools makes a big difference.
Visually, PLATSA offers a lot of flexibility: various fronts, doors, compartments with or without flaps, colors, and partly combined materials. This allows you to customize the units to suit your room and style.
I’m curious: how large is your room and how tall do you want your dividing wall to be? This greatly affects the choice of modules and stability considerations.
GALEO4
17 May 2023 13:09
Interesting question!
onatsau schrieb:
I’m particularly curious about how stable the constructions are, whether the shelves work well in different room sizes, and how visually flexible they can be.
In my opinion, the PLATSA units are often overestimated as room dividers. Yes, they look visually solid, but anyone who seriously wants a permanent room partition should consider whether this doesn’t remain a half-hearted attempt.
If you really want to separate spaces, stability is only one factor – the PLATSA units are lightweight and can easily tip over in homes with children or pets. Additionally, they offer little sound insulation or visual openness, which is not always desirable.
Personally, I would opt for more solid, perhaps even built-in solutions as room dividers, especially in living or working areas where privacy is important.
Of course, Ikea and PLATSA are great for flexible, temporary solutions or if you want to keep rearranging frequently. But anyone serious about it should think this through carefully.
PeoDaniel
17 May 2023 15:57
I would like to add a few points to the discussion, especially to clarify some technical aspects.
Regarding stability, the PLATSA units should always be anchored at multiple points—whether to the wall, the floor, or to each other. This is not an issue specific to Ikea; it is a basic principle for freestanding shelving units: stability through fixation.
I always recommend:
- Planning the number and combination of units to create a balanced structure.
- Carefully considering the weight on the shelves: place heavier items on the lower shelves and distribute weight evenly.
- Following the assembly instructions closely, especially regarding how the units are connected.
In my experience, the flexibility in design and customization is indeed a major advantage of PLATSA. Different fronts, doors, open compartments, and drawers provide plenty of options for individual solutions. They are excellent for small to medium-sized rooms when you want to cleverly zone the space.
Finally, a brief note on assembly: it helps to have two people, as some units can be bulky or awkward to handle. Overall, however, it is quite manageable even for DIYers with moderate experience.
I’m happy to assist with more detailed planning if you share more information about your room and the desired dimensions.
Nakar33
18 May 2023 08:14
GALEO4 schrieb:
Personally, I would lean towards more solid, perhaps even built-in solutions for a room divider
That is certainly a very valid point and really depends on what you expect.
For those who value the DIY aspect and flexibility, PLATSA shelves work very well, but it’s true that the stability is only sufficient up to a certain level.
If you plan very tall and wide room dividers that should also serve as support or carry heavy loads, you should definitely consider other options.
It is interesting that the modules can also be combined with LED lighting or have a deliberate mix of open and closed surfaces to play with light and atmosphere in the room division.
Assembly recommendations:
- At least two people for installation
- Use the IKEA connecting elements
- Additional screws or brackets for stabilization if necessary
How large is your room, onatsau, and what kind of atmosphere do you want to create?
neoren
18 May 2023 11:37
The PLATSA shelves are stable when properly connected and not just standing loosely. For room dividers, always screw them together and ideally secure them to the wall. They are good for visually flexible space separation due to the interchangeable fronts. Assembly is quick, and the instructions are clear.
