ᐅ What effect do wood oils have on Ikea HEMNES furniture?
Created on: 16 Jan 2021 18:27
kiraken
kiraken
16 Jan 2021 18:27
Hello everyone, I have a question that I haven’t been able to find a satisfying answer to so far: What effects do wood oils have on Ikea Hemnes furniture, especially on the wood and surface quality?
I plan to oil a HEMNES sideboard and want to know whether wood oils enhance or rather change the typical texture and appearance of the solid pine furniture, how well the oils protect the wood, for example against moisture or scratches, and if there are different results depending on the type of oil used.
Are there any experiences regarding which oils are particularly suitable and how often the treatment should be reapplied? I would also be interested to know whether the oil lightens or deepens the wood color, or if there is a risk of darkening over time. I would appreciate your tips and experiences.
DUVIN
16 Jan 2021 18:45
Wood oils enhance moisture resistance and give the wood a richer tone. This works well with HEMNES furniture made from pine, making the surface warmer and slightly darker. Important: apply several thin coats and allow each to dry thoroughly.
Palenar
16 Jan 2021 19:05
I can share some insights on how wood oils affect Ikea HEMNES furniture. These pieces are made from solid pine wood, which is naturally quite porous and can quickly absorb stains or moisture without protection. Wood oil penetrates deeply into the wood fibers and seals the pores without creating a protective varnish layer on the surface.
It is important that the oil preserves the natural feel of the wood while leaving a matte to slightly glossy finish. The color of the wood often appears more intense and warmer after oiling, enhancing the yellowish to reddish tones typical of pine.
Application is best done in several thin coats using a lint-free cloth or a brush, with each coat allowed to fully cure for about 12 to 24 hours. A rough recommendation for HEMNES is to use linseed oil or a specialized hardwax oil. Hardwax oil provides extra protection against scratches and water marks thanks to its combination of oil and wax.
Be careful not to apply too thickly, as this can cause sticky spots. Regular maintenance treatments every 1 to 3 years help preserve the protective layer and appearance.
My question to you: Are you aiming for a professional finish, or do you want the furniture to remain as natural and "breathable" as possible? This will influence your choice of oil.
kiraken
16 Jan 2021 19:37
Palenar schrieb:
My question to you: Are you planning a professional finish, or do you want the furniture to "breathe" naturally as much as possible? This affects the choice of oil.
I want to preserve the natural look and feel as much as possible, so I’m looking for a kind of surface protection that allows the wood to breathe. I would rather avoid a lacquer-like protective layer. Therefore, I’m leaning towards an oil that I can apply myself without much special equipment or professional tools. How do linseed oil and hardwax oil compare when used on HEMNES furniture? Are there differences in terms of color change and protective effect?
Rodolfo
16 Jan 2021 20:02
Linseed oil penetrates deeply and highlights the wood grain, noticeably darkening the wood and providing basic protection against moisture. However, it is quite sensitive to scratches and requires regular reapplication.
Hardwax oil combines oils and waxes, offering improved resistance against scratches, water, and dirt. The surface feels silkier, and the color is usually slightly more matte compared to pure linseed oil. The wood darkens slightly, but the change is more controlled than with linseed oil.
For HEMNES furniture made of pine, I recommend hardwax oil because it increases protection and keeps the surface quality more stable. The application is somewhat more labor-intensive, as wax layers need to be thoroughly rubbed in and excess wax removed.
Jeanbar
17 Jan 2021 09:13
I would like to add that when applying wood oil to HEMNES furniture, there are some important points to keep in mind:
- Preparation: The wood should be clean, dry, and sanded as smoothly as possible with fine-grit sandpaper, for example, 180–220 grit.
- Application: Apply thin coats using a soft cloth or brush, and wipe off any excess oil shortly after application to prevent sticky surfaces.
- Penetration time & drying: Allow at least 12 to 24 hours for drying; it may take longer in cold or humid weather.
- Repeating: Especially with untreated pine wood, multiple treatments are recommended, and maintenance should be checked annually.
I often see users applying the oil too thickly, which leads to sticky or blotchy surfaces. This should definitely be avoided. Additionally, some oils (such as linseed oil) can have a slight yellow tint, which should be considered with lighter HEMNES wood.
