ᐅ What should I do if the sides of my IKEA Metod cabinets are crooked?
Created on: 14 Apr 2022 09:12
U
ulises5
Hello everyone, I recently noticed that the side panels of my Ikea Metod kitchen cabinet are installed crookedly. Specifically, one side is slightly leaning outward, which causes the doors and drawers not to close properly. I have already checked that the floor is level and that all screws are tightened correctly, but the gap remains. My question is: What exactly can I do if the side panels of an Ikea Metod cabinet are crooked? Has anyone had experience with adjusting them or any helpful tips on how to straighten the side panels? I would appreciate a detailed response.
RETRAVIS
14 Apr 2022 13:15
It is important to approach the problem systematically. Summary of the actions:
- Check the floor, wall, and back panel.
- Align the side panels and temporarily fix them in place.
- Use a spirit level – horizontally and vertically.
- Slightly loosen the screws on the fittings, position the side panels, then tighten the screws again.
If the side panels still do not fit, a material defect or manufacturing error is likely. In this case, making a claim with Ikea may be useful. Alternatively, self-adhesive leveling profiles can sometimes help.
U
ulises5
14 Apr 2022 16:10
LOGEMIN schrieb:
Material warping is rather rare with Ikea Metod, but not impossible.
Thank you, that helps me move forward. Today, I carefully disassembled the cabinet, removed the back panel, and adjusted the side panels. It really seems that the left side panel is slightly warped. However, the material is not damaged, just minimally bent. I will try to level it out at the bottom using small wooden shims. Could this cause long-term issues or reduce stability?
Lilau
14 Apr 2022 17:05
I would say that if the adjustment with wooden wedges is done carefully and the panels are not subjected to increased stress or deformation, the risk is low. It is important that the wedges are securely fixed and do not allow any movement. In my experience, this worked well, but I also made sure to firmly attach the cabinet to the wall.
pikin
14 Apr 2022 18:42
Regarding stability: The Metod system is generally very stable when all parts are properly screwed and fixed. Using wooden wedges to compensate can relieve a small area, but it causes problems if the wedges shift or permanent support is not ensured. Pay attention to:
- Wedges made of suitable wood with the right thickness (do not force)
- Securing them, for example with wood glue or screws
- Don’t forget to attach the back panel, as it significantly stabilizes the structure.
enrique7
15 Apr 2022 08:50
It is interesting that only one side is affected. This actually suggests a material defect. Therefore, the question is whether investing in aids such as wedges or repairs makes sense, or if it might be more cost-effective, especially in the long term, to replace the component. Has Ikea offered a replacement in your case? In my opinion, a complaint with detailed information about the warping of the side panel would be the right approach.
GALEO4
15 Apr 2022 09:27
enrique7 schrieb:
Interesting that it only affects one side.
I think the focus on complaints is exaggerated. Many people quickly opt for replacement instead of checking possible adjustments. Honestly: a slightly warped component hardly matters if you correct it smartly.
Why not simply adjust it yourself using suitable shims and screws? This is more sustainable and makes you more independent. Even replacement parts rarely fit perfectly. Ikea furniture simply has production and tolerance allowances.
