ᐅ What can you do if the drawers of the Ikea Brimnes cabinet are loose or wobbly?
Created on: 21 May 2020 08:46
Johan_tan
Johan_tan
21 May 2020 08:46
Hello everyone, I have an issue with my Ikea Brimnes furniture, specifically the drawers, which have started to wobble noticeably over time. The drawers no longer sit firmly on the drawer slides and make a slight creaking noise when opening and closing. My question is: What can be done specifically when Ikea Brimnes drawers wobble? Is there a way to adjust the drawer slides or possibly replace worn parts? What are the most common causes for the drawers losing their stability? I have already tried tightening the screws, but without lasting success. I would appreciate any help with concrete tips and experiences.
Nigel
21 May 2020 10:13
The most common cause is loose screws on the running rails. Make sure to tighten the screws properly and also check the rear fastenings. If the running rails are damaged, you will need to replace them. You can simply inquire at the Ikea service, as replacements are usually available without any issues.
O
onMarcos
21 May 2020 12:39
Hello Johan_tan,
to permanently fix the wobbling of the drawers in Ikea Brimnes, the following steps are recommended:
- First, pull the drawer out completely and inspect the entire slide system for any damage. Look for bent or loose parts.
- Make sure to tighten the screws that secure the slides, especially those at the back, as these are often overlooked.
- Also, check if the plastic gliders on the slides are properly positioned and not worn out. Damaged gliders can quickly cause drawer wobbling.
- If the issue is with the drawer itself: sometimes the side rails can warp or become loose over time. Replacing the guide rails, which Ikea offers as spare parts, often helps here.
- Finally, it is advisable to open and close the drawer several times after reassembly to allow the slides and gliders to settle evenly.
Many problems arise from overloading or uneven weight distribution in individual drawers. So also ensure that the load is appropriately distributed.
Summary: Check and secure screws, inspect or replace gliders, examine slides and order replacements if necessary. This usually results in stable and long-lasting functionality.
RON57
22 May 2020 09:18
Johan_tan schrieb:
My question is: What can be done if Ikea Brimnes drawers wobble? Is there a way to adjust the drawer slides or perhaps replace worn parts?
Hello Johan_tan,
You are right to point out that the drawer slides cannot really be adjusted in the sense of repositioning them in small increments, but you can try the following:
- Tighten any loose screws.
- Replace the plastic runners, which are a common wear point on Brimnes drawers.
- Check if the drawer was installed properly, as installation errors can sometimes cause wobbling.
When drawers wobble, it is usually due to stretched drawer slides or damaged runners. Replacement parts are available from Ikea and are relatively inexpensive. If you are somewhat handy, you can replace the runners yourself and significantly improve stability.
If the drawer slides are heavily warped, it is better to replace them completely. Good luck!
draleo
22 May 2020 20:07
To complement and summarize the previous advice:
The wobbling drawers in Ikea Brimnes are usually caused by mechanical wear of the built-in components. The metal drawer slides use plastic runners that can wear out or break over time.
From a technical perspective, the following steps help:
- Check for loose fasteners, as these can cause instability.
- Replace the plastic runners if visible damage is present or if they cause play in the drawer.
- Inspect the drawer guides within the cabinet to identify any assembly errors or if the furniture is warped.
Adjustments in the traditional sense are not intended, since this is a pull-out system with pre-attached slides. The goal is to secure loose parts again and replace damaged components with suitable spare parts.
Ikea usually offers replacement runners or complete drawer slide sets separately. Replacing these parts is straightforward and significantly extends the drawers’ lifespan.
Also consider: excessive loads or improper use can increase wobbling. Even load distribution in the drawers is recommended.
These measures ensure a stable drawer system for Brimnes in the long term.
