ᐅ What are common assembly mistakes with Ikea Metod cabinets and how can I avoid them?
Created on: 24 May 2020 08:17
PaparHello everyone, I’m starting a discussion on the topic "What are common assembly mistakes with Ikea Metod cabinets and how can I avoid them?"
I’m mainly referring to typical errors that often occur during the installation of kitchen cabinets from the Metod series. I’m interested in common pitfalls such as mixing up parts, mistakes in aligning the cabinets, incorrect screwing, or issues with fixing them to the wall.
I understand that there are always challenges with self-assembly, but it would be great if you could share from your experience which mistakes you find most frequent and, above all, how to best avoid them.
Are there any tips regarding tool selection, assembly techniques, or procedures that have helped you?
Thanks in advance for your feedback!
Hey Papar, nice question, it really speaks to me! ☺️
With Metod, I often see people rushing to start – this quickly leads to mixing up the cabinet sides or mounting the hinges the wrong way. It’s easy to do if you don’t carefully study the instructions first. My advice: stay calm and take it step by step.
Also, it often happens that the cabinets are not perfectly level. A spirit level and paying attention to every centimeter (inch) are really invaluable! I’ve made it a habit to check the alignment after every important step.
A little insider tip: screw the screws in loosely at first and only tighten them fully after the entire assembly is complete. This way, you can still make adjustments if something isn’t fitting exactly.
Looking forward to hearing what others say. Good luck with your project!
I’ll add a few points based on my experience:
- A common mistake is installing the back panels too late or not at all. They not only provide stability but also help in aligning the cabinets.
- When fixing to the wall, the importance of choosing the correct fastening materials for the wall type is often underestimated. Using the wrong anchors can lead to insecure attachment later on.
- Another tip: Don’t just drill holes blindly according to measurements; if possible, test them first on a frame or a wall section.
These are issues I frequently notice and can be avoided by taking a few extra minutes.
Interesting contributions so far. I would like to suggest that we also discuss the impact that planning before the actual construction has on the error rate.
Assembly errors are often the result of incomplete or inaccurate planning. These include, among others:
- Incorrect choice of cabinet sizes, leading to inflexible positioning
- Failure to consider walls, windows, or door openings
- Lack of assessment of floor levelness
Could this also be considered when discussing “assembly errors with Ikea Metod”? If the planning is not done properly, errors during construction are almost inevitable.
theo63 really made a very important point! 🙌
Sometimes the problem isn’t just with assembly, but starts much earlier. Still, I want to share something funny: I know someone who installed the hinges upside down and then thought the kitchen was broken when opening it 😂
But in general, I completely agree: Planning = half the success!
Another installation mistake I often see is poor alignment of the countertop with the cabinets. The countertop then gets stuck or overhangs. My tip: always adjust the countertop at the end, don’t install it too early.
ritotar schrieb:
A small tip: first screw in loosely and only tighten fully after completing the entire assembly. This way, you can still adjust if something isn’t fitting perfectly.I can only agree with that. 😄 I once made the mistake of tightening screws right away. It resulted in me having to completely disassemble a cabinet later because a small misalignment had occurred.
Also, I've noticed that having the right tools, especially a good cordless drill, makes a big difference. It's better to have a device with torque control to avoid over-tightening.
And: Always double-check the instructions, ideally several times. Some steps look different in the pictures than they really should be.
