ᐅ What are the most common mistakes when assembling the IKEA BRIMNES?
Created on: 26 Oct 2024 18:27
MeoromanHello everyone, I am planning to assemble the IKEA Brimnes series at home and would like to hear about your experiences. I am especially interested in the most common mistakes that occur during assembly – whether related to fitting accuracy, the assembly instructions, or mechanical issues like screws and fittings. What typical pitfalls have you noticed that one should definitely watch out for to avoid rework or damage? Are there any special tips regarding the order of assembly or frequently misused parts? Any detailed feedback would be helpful to complete the project smoothly from the start.
A common mistake with the BRIMNES is definitely the inaccurate alignment of the individual modules, especially with the drawer units. This often causes the drawers not to close smoothly or to get stuck. I recommend checking the fit of all parts carefully before screwing them together and, where possible, pre-drilling the holes to avoid screw tension. Another frequent issue is assembling the back panel, which is often installed last – be sure it sits completely flush, as otherwise the entire structure can become crooked. I also advise tightening the screws gently, since the MDF material can quickly swell or split if too much torque is applied. Finally, I can say that the assembly instructions are generally good, but you should really follow each step carefully and not skip any, especially if you are inexperienced.
First of all, I think your question is well formulated and very helpful for anyone looking into BRIMNES. I have assembled the wardrobe twice, and my experiences are similar: the assembly instructions can be a bit confusing at times, especially the illustrations of the back panel and the drawer runners. Make sure to check that you have all the parts before you start – sometimes small screws or dowels are missing. Also, the order of assembly is crucial: the side panels and the carcass should be aligned flush first before you start with the drawers. Small squares or a tape measure can help with the alignment. Another common mistake is installing the shelves without guiding aids, which can lead to an unstable structure later on. A small tool set with a Phillips screwdriver and an Allen key proved indispensable for me.
In summary, the most common mistakes when assembling the BRIMNES system are as follows: - Incorrect assembly sequence, especially attaching the back panel too early or too late. - Over-tightening screws, which can damage the material since BRIMNES is made of MDF. - Insufficient alignment of parts before final screwing, such as the drawer boxes, leading to misfits. - Failure to check whether all parts are complete and match the assembly steps, especially fasteners. My advice: Always use a screwdriver with torque control and follow the instructions carefully. Errors in the assembly order are the most frequent cause of problems later on.
I would like to dive a bit deeper into the issue, especially regarding the drawer slides. BRIMNES often uses metal rails with integrated ball bearings. Proper locking is critical: incorrectly installed slides not only cause drawers to stick but can also affect the entire functionality. I recommend initially installing the slides loosely, then testing the cabinet by opening and closing the drawers before fully tightening everything.
Another detail that is often underestimated concerns the connectors (dowels, cam locks). They are frequently not fully inserted, which typically only becomes noticeable when stress causes deformation. It helps to carefully insert each element by hand first and then tighten it with the appropriate tool.
Additionally, MDF can expand due to environmental humidity if there are assembly errors, so it’s best to choose a relatively dry room for assembly. I would like to know if anyone has experienced issues with warped fronts, as this could be due to incorrect tightening of the screws.
