ᐅ What alternatives are available if the Ikea Pax system is not an option?
Created on: 11 Jan 2017 14:37
Foso36
Foso36
11 Jan 2017 14:37
Hello everyone, I am currently facing the problem that the planned wardrobe from the Ikea Pax system is not available for the time being. Demand seems to be higher than supply, and I don’t want to wait for months. Therefore, I’m interested in knowing: What alternatives are there if the Ikea Pax wardrobe is not available? I am looking for something similarly flexible and modular, ideally with comparable dimensions and design. Are there proven systems or manufacturers that offer similarly versatile furniture? Or maybe practical solutions that can be assembled or customized on your own? I appreciate any tips, especially if anyone has experience with alternatives to Pax.
Annedeo
11 Jan 2017 15:22
Hello Foso36, your question is very well formulated and shows that you have already considered the key requirements. If the Ikea Pax is not available, there are indeed some useful alternatives that you can consider. First, you should think about what is most important to you: flexibility, value for money, or design. A few options would be:
- The wardrobe system from Höffner, which is similarly modular and also offers custom sizes.
- The Elfa system from the company Elfa, which is often used in Germany as a flexible solution for interior fittings.
- Custom-made furniture from local carpenters, which is more expensive but tailored exactly to your needs.
It is important that you know the exact dimensions, as not every manufacturer offers the same width, height, or depth as Pax. In addition, you can achieve almost the same flexibility with modular components and shelving systems, for example from Dexion, or even modular clothes rails and shelves from manufacturers like Tylko. If you want, I can also give you tips on how to combine such systems effectively.
If you are more interested in individual solutions, it is worth looking for used Pax systems in good condition, as many sell them cheaply when moving or renovating.
Mufato
11 Jan 2017 17:03
Annedeo schrieb:
If the Ikea Pax is not available, there are actually some useful alternatives you can consider.
My tip: Check out 'Mondi' or 'Roller', as they often have similar systems. Or you can opt for simple shelving units with fabric boxes if you want to keep it flexible.
dinano
12 Jan 2017 09:46
Foso36 schrieb:
I’m looking for something similarly flexible and modular, ideally with comparable dimensions and design.
That’s exactly the point where many underestimate how specific Pax actually is. The modularity ensures that the interior can be customized with drawers, clothes rods, shelves, and so on. Without knowing the exact needs, however, I think it would be risky to simply choose a different brand just because it looks ‘similar.’
Anyone interested in alternatives should carefully check whether they fit their room layout and storage requirements. I often question whether these cheaper replacement systems are only visually similar but significantly inferior in quality and durability.
So here’s my counter question: Have you considered whether second-hand options might be suitable? Or would a custom-made solution be an option? Both approaches could potentially be more effective than risking a wrong decision with a similar modular system.
Annedeo
13 Jan 2017 11:18
dinano schrieb:
Those interested in alternatives should definitely check whether they fit their room layout and storage needs.
That’s an excellent point. Especially with height or width restrictions in tight spaces, a custom-built system can offer advantages.
I would also add that while modular fitted wardrobes, often offered by carpenters, tend to be more expensive, they can provide better long-term durability and a more seamless integration into the room’s aesthetics.
Additionally, I want to recommend the Liv’Inn system, available in some furniture stores. Although not as well known as Pax, it also offers modular combinations with good flexibility and an elegant design. However, you should look at samples before purchasing to objectively assess the quality.
In general: Some alternative systems are based on different construction principles, such as focusing more on metal frames instead of wood-based materials. This can have pros and cons depending on your taste and the load capacity your wardrobe requires.
