ᐅ External venetian blinds or roller shutters on the south side of the house?
Created on: 24 Aug 2016 21:31
Grym
We will most likely install roller shutters on all sides except the south side. Only on the south side are we considering whether venetian blinds make sense. Here are our floor plans with the precisely aligned north arrow:
Floor plan of a multi-story house: living room, dining area, study, utility room, stairs, doors.
Floor plan of a house with bedrooms, bathroom, shower, dressing room, and utility room.
The eaves of the hipped roof (2 full stories) are planned to be 60cm (24 inches) deep. We plan to place a very large sun sail in front of the house, roughly 6x4m (also available in 7x5m or 5.6x5.6m – depending on the manufacturer). Here is a picture:
Floor plan of a living area with dark blue U-shaped sofa, dining table, doors, and dimensions.
The deepest corner of the sail would be the upper left corner. The sun sail would be deployed either only as needed or definitely only during the summer.
The reason for the venetian blinds is clear: when the weather is nice outside, you want some shading but not too much, as you don’t want to feel completely shut off from the good weather while inside. In our living/dining area, the two windows in the dining and kitchen areas can be fully opened since they are no longer directly exposed to the sun. In my opinion, the south-facing window in the dining area and the middle window from the sun sail should be protected, so that only the two roller shutters in the living area would be closed.
But actually, much more importantly in my opinion: if the weather is so nice that the sun is shining and it’s warm outside, then I go out under the sun sail to relax, grill, eat outside, etc. – in that case, I’m happy to lower ALL the roller shutters because I’m not inside. It’s different at work, where we also have a venetian blind. I can’t just go outside, sit under a sun shelter, and relax comfortably there. At work, I’m forced to be inside and appreciate the partial shading provided by the venetian blind.
I prefer roller shutters because you can fully close them. This is important for the children's rooms when the kids want to sleep. Our plot is also somewhat on a hill (about 100 meters (330 feet) above the city center). We are not right at the top, but still quite high up, and it’s windier and stronger here than downtown. Above a certain wind speed, the venetian blinds automatically go up, which is not ideal.
Above all, with our 6 windows and 3 of them having venetian blinds (which have two movement dimensions in contrast to roller shutters – up/down and horizontal/vertical), it can get really complex, so automation would need to be considered.
But my main points are:
- Depending on how the sun sail is used, 2 or 4 of the 6 windows can stay open, so plenty of light will come in anyway.
- If the weather is so nice outside, then you’re outside anyway, so partial shading doesn’t help me because I’m not inside.
Sebastian79
25 Aug 2016 10:07
I paid around 2,500 euros for three larger venetian blinds – that’s about the same amount I paid for eight electric roller shutters (rough estimate).
Curly
25 Aug 2016 10:10
How wide was one of the larger venetian blinds?
Sabine
Sebastian79
25 Aug 2016 10:20
2.50m (8 feet 2 inches), the other two 2.0m (6 feet 7 inches).
andimann25 Aug 2016 17:44
Hi,
Compared to mechanical or electric roller shutters?
Curly schrieb:
do you know how much extra Raffstores cost compared to roller shutters?
Sabine
We have 7 Raffstores at our place,
5 of them are 210 cm (83 inches) high and about 180 cm (71 inches) wide
1 is 210 cm (83 inches) high and about 90 cm (35 inches) wide
1 is 110 cm (43 inches) high and about 180 cm (71 inches) wide
The additional cost was about 2500 € compared to electric roller shutters. The roller shutters themselves had already added a good 2000 € extra.
For us, it was worth it because with Raffstores we could have some fixed window elements. You no longer have the problem of needing to clean roller shutters from the inside. This almost compensated for the extra cost.
But important:
No Raffstores in bedrooms, ONLY roller shutters work there!
Our neighbor made a mistake with the children’s rooms and ended up having to buy very expensive blackout curtains because his kids couldn’t sleep.
Andreas
Grym
25 Aug 2016 18:25
Sebastian79 schrieb:
Sometimes your assumptions are just odd – nice weather is no longer nice at 30 degrees Celsius (86°F) or above.
Only the tough get into the garden.
Of course, I have unusual assumptions; otherwise, I wouldn’t be asking...
We only have them on three windows downstairs; the upper floor has roller shutters...
That requires a lot of automation too, right? That just makes it more expensive again...
Sebastian79
25 Aug 2016 18:29
Why so much automation? The controls at the bottom and top are completely separate.
