ᐅ External venetian blinds or roller shutters on the south side of the house?
Created on: 24 Aug 2016 21:31
Grym
We will most likely install roller shutters on all sides except the south side. Only on the south side are we considering whether venetian blinds make sense. Here are our floor plans with the precisely aligned north arrow:
The eaves of the hipped roof (2 full stories) are planned to be 60cm (24 inches) deep. We plan to place a very large sun sail in front of the house, roughly 6x4m (also available in 7x5m or 5.6x5.6m – depending on the manufacturer). Here is a picture:
The deepest corner of the sail would be the upper left corner. The sun sail would be deployed either only as needed or definitely only during the summer.
The reason for the venetian blinds is clear: when the weather is nice outside, you want some shading but not too much, as you don’t want to feel completely shut off from the good weather while inside. In our living/dining area, the two windows in the dining and kitchen areas can be fully opened since they are no longer directly exposed to the sun. In my opinion, the south-facing window in the dining area and the middle window from the sun sail should be protected, so that only the two roller shutters in the living area would be closed.
But actually, much more importantly in my opinion: if the weather is so nice that the sun is shining and it’s warm outside, then I go out under the sun sail to relax, grill, eat outside, etc. – in that case, I’m happy to lower ALL the roller shutters because I’m not inside. It’s different at work, where we also have a venetian blind. I can’t just go outside, sit under a sun shelter, and relax comfortably there. At work, I’m forced to be inside and appreciate the partial shading provided by the venetian blind.
I prefer roller shutters because you can fully close them. This is important for the children's rooms when the kids want to sleep. Our plot is also somewhat on a hill (about 100 meters (330 feet) above the city center). We are not right at the top, but still quite high up, and it’s windier and stronger here than downtown. Above a certain wind speed, the venetian blinds automatically go up, which is not ideal.
Above all, with our 6 windows and 3 of them having venetian blinds (which have two movement dimensions in contrast to roller shutters – up/down and horizontal/vertical), it can get really complex, so automation would need to be considered.
But my main points are:
- Depending on how the sun sail is used, 2 or 4 of the 6 windows can stay open, so plenty of light will come in anyway.
- If the weather is so nice outside, then you’re outside anyway, so partial shading doesn’t help me because I’m not inside.
Sebastian7925 Aug 2016 08:42I personally don’t like them at all (BiRoll Panorama looks like a prison) – plus, I wouldn’t want to know the price range of such niche products...
Grym schrieb:
Does anyone have experience with s_onro, Hella Nova daylight roller shutters, or BiRoll Panorama? What are your thoughts on these? Sonro will be installed at our place in 5 weeks. I will provide feedback.
It costs about twice as much as venetian blinds.
In bedrooms, roller blinds are advantageous (especially for shift workers) because venetian blinds cannot fully close due to their design.
Roller blinds are faster to raise and lower. This is an important consideration if you have floor-to-ceiling windows that you also want to use as doors, since venetian blinds can get in the way and would have to be fully raised.
If you still prefer venetian blinds, choose ones with two separate sections or motors. For example, 2/3 of the window area can remain covered while 1/3 is opened to allow access.
Pay attention to the color of both roller blinds and venetian blinds. For instance, if you want windows in anthracite, you can opt for roller blinds or venetian blinds in silver, which will make the room slightly brighter.
Keep in mind that venetian blinds should be connected to wind sensors. This means that in windy or stormy conditions, the blinds will automatically rise, leaving no privacy screening. This can be compensated for with options like pleated blinds or curtains.
