ᐅ Two external blinds or fingerprint scanners – which would you choose?
Created on: 11 Dec 2019 07:17
Pamiko
Pamiko
11 Dec 2019 07:17
we still have a small portion of the contingency buffer left for a little extra feature.
We have the choice between the following two options, and we want to pick one:
- Exterior venetian blinds (also called louvered blinds) on two fixed floor-to-ceiling window units next to the front door (south-facing, no roller shutters, frosted glass). Cost including control system and wind sensor is about 1350€ (approximately $1,450).
- Fingerprint scanner on the front door. Total cost is about 1200€ (approximately $1,290).
We are having a hard time deciding. Both have advantages, and we could also choose to skip both if needed.
What would you choose?
matte
11 Dec 2019 07:24
If you don’t absolutely need either, I would save the money; something else will come up eventually. Otherwise, for a south-facing orientation, I would recommend choosing external blinds. Without shading, it can get quite hot...
Winjoe1
11 Dec 2019 07:26
Saving easily!? Having an extra thousand is never a bad idea when building a house. During the construction phase and afterwards, there will likely be a few small expenses where the money can come in handy. Especially since you can do without both.
guckuck2
11 Dec 2019 07:33
Hmm, the south-facing orientation definitely supports the use of external venetian blinds. But who actually lowers the blinds at the entrance? Especially since I assume you wanted to achieve a visual effect in the entrance area with the transparent glass. How large is the glass area or the covering? It might be possible to do without the wind sensor. Especially on the ground floor, for smaller sizes, I find it unnecessary.
Pamiko
11 Dec 2019 08:43
Thank you for the answers. The buffer is still there. This is really about deciding between the two options. We set ourselves the goal beforehand not to have everything and established a budget for such things.
According to the plans, the two windows are 1.01 meters (3 ft 4 in) wide and 2.40 meters (7 ft 10 in) high. Behind them is the staircase.
Is it really possible to do without a wind sensor on the external venetian blinds? It costs over 300€ here.
Further opinions are welcome.
world-e
11 Dec 2019 08:53
Have a motorized lock installed in the door and prepare for the installation of an external fingerprint scanner.
