ᐅ Is it possible to control roller shutters with a switch and add wireless operation later?
Created on: 9 Apr 2015 22:46
Legurit
Legurit
9 Apr 2015 22:46
We have now received quotes for both radio-controlled and switch-operated roller shutters for our new build. Due to the price and partly because I’m worried about losing or misplacing the remote control, we are strongly leaning towards the switch solution.
Is it possible to retrofit radio receivers into the electrical boxes later on—if we find that constantly walking back and forth is too tiring—and then control the shutters via radio through this setup?
Also, I would be interested to know where you installed your switches—directly at the window or grouped together centrally?
Thanks for your input!
FrankH
10 Apr 2015 02:30
There are manufacturers that offer wireless actuators for retrofitting, but this is more expensive than installing a suitable system right from the start. By the way, in addition to the windows, I installed push buttons alongside the wireless control so both options are available. The motor I use already includes all functions for time control, which balances out the higher initial cost because adding timers later is usually expensive. I installed the motors and push buttons myself, so I only had to cover material costs.
I installed the push buttons close to the windows, mainly to reduce wiring effort for retrofitting, as I’m dealing with an existing property rather than a new build. It might be more practical to place the controls next to the room door if only the switch will be used. I usually use the remote control anyway, so it didn’t matter much to me.
My system is from Rademacher and can also be controlled via the internet if needed, but I don’t require this at the moment. I can add that feature later if I find a useful application for it, for example, remote control while on vacation.
Jochen10410 Apr 2015 08:15
we basically have a switch next to every window.
Additionally, in our open kitchen/dining/living area with 5 windows, we will have a central switch that controls all the roller shutters at once. This way, I want to avoid having to go around all the windows in that area every evening and morning to close or open the roller shutters. Of course, the electrician charges for the extra wiring work.
f-pNo10 Apr 2015 08:41
We have also equipped all accessible windows and doors with electric roller shutters. There is a switch next to each window.
Originally, a central switch was planned so that when everyone leaves the house, the shutters could be lowered with a single press, preventing any risk of fire. However, the electrician’s quoted price just for the preparation work (laying cables) was so high that we decided against it.
At the moment, it doesn’t bother me much to operate the shutters manually. Although my wife sometimes forgets the utility room. During the day, the shutters remain open. When we go away for a few days, we close them completely, leaving a small gap in the windows behind which plants are placed.
We have also been told that it is possible to retrofit remote control later. Additionally, as @FrankH has already mentioned, there is an option to set up control via the internet or a smartphone app. Personally — maybe I’m old-fashioned or just not technically up to date — I worry that such systems could be hacked if they operate over Wi-Fi.
Doc.Schnaggls
10 Apr 2015 09:31
this is how we solved it in our house:
Each roller shutter has its own switch. However, in the living and dining area, we grouped the switches. So all switches for the windows facing south and all switches for the windows facing west are grouped together.
In the other rooms of the house, the switches are located next to the respective window.
We did not want a central control system.
Regards,
Dirk
Kikolool
10 Apr 2015 10:51
We have radio-controlled motors, but with external switches that you can basically stick anywhere on the wall. There is also a remote control, which allows me to group individual blinds together.
So, I can walk to the window and press the button, set an automatic program (timer), or operate the groups using the handheld remote.
This was the most flexible solution for us.
