ᐅ Using a BILLY Shelf on the Terrace – What Are the Options?
Created on: 18 Mar 2021 08:37
JABESI
JABESI
18 Mar 2021 08:37
I am planning to use a BILLY bookshelf from IKEA on my terrace, and I am uncertain about what is actually feasible and which points I should definitely consider. My terrace is covered but unfortunately not fully protected from weather conditions, so moisture and temperature fluctuations are certainly possible.
I am especially interested in whether the BILLY bookshelf can simply stand outside without quickly getting damaged, or if special measures like sealing, a base support, or covers are necessary. Are there any experiences regarding how durable the material is for outdoor use?
Additionally, I wonder if the bookshelf should be assembled or secured differently since terraces can be quite uneven and wind is also a factor.
Do you have any tips for preparation or use to keep the bookshelf practical on the terrace and make it last as long as possible? I would appreciate any experience reports, technical advice, or product alternatives.
Thank you in advance!
gekira
18 Mar 2021 09:13
The BILLY shelf is primarily designed for indoor use since it is made of particleboard, which handles moisture very poorly without special treatment.
If you want to use the shelf on your terrace, I strongly recommend treating the back and all visible surfaces with a moisture-resistant coating, such as clear varnish or polyurethane-based paint. A permanently protected location (covered and sheltered from wind) is essential; otherwise, the wood will quickly swell and the stability will suffer.
For the base, you should choose a level, solid surface; wood or stone slabs are ideal. Avoid direct contact with the ground to prevent waterlogging, for example by placing the shelf on feet or spacers.
Additionally, anchoring the shelf is advisable to prevent it from tipping over in strong winds, for instance by screwing it to the terrace structure or using wall brackets specially installed for this purpose.
In short: “placing it untreated and without protective measures on the terrace is not advisable.” If you cannot treat it, weather-resistant alternatives are more suitable.
taudi
18 Mar 2021 09:58
I am happy to add to gekira’s advice with a step-by-step guide on how to use the BILLY shelf on a terrace if you don’t want to buy a new weather-resistant shelf right away:
1. Cleaning: First, thoroughly dust the shelf and clean it with a damp, mild cloth.
2. Sanding: Gently sand any minor uneven spots or rough areas to help the protective coating adhere better.
3. Sealing: Apply at least two coats of varnish or wood preservative that repels moisture (observe the drying times!). Be sure to coat all edges and the back sides.
4. Adjusting feet: Attach either plastic feet or small wooden blocks as spacers under the shelf legs to prevent the wood from direct contact with the ground.
5. Securing: Firmly fix the shelf to the wall or, if necessary, to the floor with brackets to minimize the risk of tipping due to wind.
6. Covering: If possible, use a cover made of water-repellent material when the shelf is not in use for extended periods or during heavy rain.
7. Inspection: Regularly check for moisture or damage and renew the protective coating as needed.
Mistakes to avoid: Leaving the shelf unprotected outdoors or coating only parts of it. Also, placing it on an uneven or soft surface can increase damage caused by moisture.
Espen
18 Mar 2021 10:07
BILLY is not designed for outdoor use.
Painting helps but does not guarantee protection against swelling.
Keeping a gap from the ground is mandatory.
It is better to use furniture made of metal or plastic.
Domau0
19 Mar 2021 14:41
A brief addition to the previous tips:
The particleboard panels of the BILLY shelf are very sensitive to moisture. Even small damp spots can cause swelling damage. Applying a clear varnish provides an initial protective layer, but I recommend also treating the shelf with a wood preservative and applying at least two full layers of varnish.
Since the terrace is only covered and moisture can still penetrate from side winds or splashing water, you can also place a protective foil under the shelf. This foil is meant to prevent rising moisture from directly affecting the underside.
To achieve a stable position on uneven ground, I recommend fitting the feet with adjustable furniture glides. These are inexpensive and available at hardware stores. This way, you can easily compensate for unevenness and better distribute the load.
Additionally, you should check whether your terrace tends to form puddles or holds water for extended periods in that spot, for example due to poor drainage. Over time, this would negate the protective measures.
gekira schrieb:
If you want to use the shelf on the terrace, I strongly recommend treating the back and all visible surfaces with moisture-resistant products
I totally agree with that.
What about usage? Do you want to keep the shelf there temporarily or permanently?
And what will be stored on it? Plants, grill accessories, decorations? That will influence the choice of protective measures.
