ᐅ What should be considered when using Billy shelves in damp rooms?
Created on: 20 May 2020 08:17
DUTINAR
I am planning to install a Billy shelf from Ikea in my bathroom. Since it is a damp room, I am wondering what should be considered when using these shelves there.
I am particularly interested in how moisture might affect the particleboard material and the surface coating, whether the shelf needs special treatment or installation methods, or if there are already alternative options or materials that are better suited.
Does anyone have experience with this and can explain what precautions should be taken when using Billy shelves in damp rooms to avoid damage or premature deterioration? Perhaps also insights into how moisture affects the shelf over time and which preventive measures are recommended.
Thank you in advance for your support!
Thank you for the information so far.
I am still interested in whether the edges can be sealed with a special product. Do you have any tips on suitable wood preservatives or varnishes that provide long-lasting moisture resistance?
Or is this only minimal protection that quickly loses effectiveness with frequent exposure to moisture?
Does anyone have specific experience or recommendations regarding this? I would prefer not to have to dispose of the shelf after a short time.
DUTINAR schrieb:
I’m also interested in whether the edges can be sealed with a special product.Yes, they can and should be sealed. For example, a waterproof coating with acrylic paint or specialized wood protection varnishes available at hardware stores is recommended. Products with high water repellency often contain polyurethane or acrylic blends.
These effectively protect the cut edges against water penetration, which can cause swelling and damage in particleboard. However, this protection is not completely waterproof but significantly reduces the risk.
It is important to apply the coating evenly and carefully to the edges and to reapply as needed over time.
For rooms that are permanently or frequently exposed to moisture, this is not a guarantee but rather a preventive measure that helps to extend the service life.
DUTINAR schrieb:
Does anyone have precise experience or recommendations on this?I have seen many Billy shelves in bathrooms that have lasted for years with additional sealing and good ventilation. In my view, the most important factors are:
- Properly sealing the edges (e.g., with clear varnish or wood oil specifically designed for humid rooms)
- Avoiding direct contact of the shelf with water
- Regularly ventilating the room
If these points are followed, the durability can be significantly improved. However, Billy is not furniture intended for true wet areas (showers, bathtub surroundings). For these, it is better to choose furniture specifically labeled as waterproof.
Hey, I find this topic really interesting! 🙂
I’ve had a Billy shelf in my bathroom for almost two years now – not right next to the shower, but on a drier wall.
Before setting it up, I treated the edges with a waterproof clear varnish and make sure it doesn’t get exposed to heavy moisture. So far, no warping or damage.
So, with a bit of care and attention, it works perfectly! ;-)
Deandre schrieb:– That’s really an important tip!
Do not let the shelf come into direct contact with water
Matthewt4822 May 2020 09:43DUVIN schrieb:
A water-resistant shelving material is recommended.I completely agree with that. If the Billy shelf is going to be used long-term in a damp room, wood-based panels with moisture resistance classification or aluminum/metal are the better choice.
With protective coatings and good maintenance, you can certainly extend its lifespan in areas with lower humidity. However, particleboard furniture is fundamentally not suitable for truly wet environments.
If you want to stick with Billy, it should definitely be placed in a rather dry niche.
