ᐅ What weight can the Billy shelf hold without sagging?
Created on: 11 Nov 2024 18:37
Sethfi
Hello everyone, I have a question that I hope some of you with practical experience can answer. I’m planning to use an IKEA Billy bookshelf in my home office and am wondering how much weight a single shelf can actually hold without permanently sagging or deforming. Specifically, I’m interested in the maximum weight that can be stacked on one shelf of the Billy bookshelf when loaded normally with everyday items like books, binders, or similar.
I’m aware that IKEA provides a load capacity rating, but I often read about safety margins or variable load capacities depending on the shelf’s length and material. Does anyone have exact experience or even measurement data that could provide a realistic value? It would also be helpful to know whether reinforcing measures are advisable or necessary, such as additional supports or other techniques to prevent sagging.
Thanks in advance for your input!
nubar
12 Nov 2024 12:43
As an addition to the topic of load capacity: In a similar project, I loaded the Billy shelf with about 18 kg (40 lbs), distributed over shelves approximately 80 cm (31.5 inches) wide, and the load held well over two years, although there was a slight sagging noticeable.
I would estimate that the maximum load for permanent use is around 15 kg (33 lbs) per shelf without reinforcement, and 18–20 kg (40–44 lbs) with reinforcement. If you want to reinforce it cost-effectively, simple metal angle brackets screwed to the underside of the shelf are sufficient. It is important to distribute the load evenly and avoid placing the center of gravity in the middle.
Sethfi
13 Nov 2024 08:23
KAULIS schrieb:
Attach the strips lengthwise, secure them with screws, pre-drill holes, and apply as little pressure as possible to the edges.
That sounds doable. Is there a recommendation regarding the type of wood for the strips? Hardwood like beech or rather softwood like spruce? And should the strips be painted or treated before screwing to prevent warping?
I’m looking for the most stable and durable solution without having issues after a short time due to moisture or temperature changes.
Dilen
13 Nov 2024 08:57
Sethfi schrieb:
Is there a recommendation regarding the wood for the molding strips? Hardwood like beech or rather spruce?
Beech or another hardwood is generally more stable and less prone to warping, but it is also somewhat more expensive. Spruce is lighter, cheaper, and usually sufficient as long as the molding strips are not too thin. The key point is to keep the strips dry and protect the ends and surface against moisture with a simple stain or clear varnish.
Sethfi schrieb:
Should the molding strips be painted or treated before screwing them in to prevent warping?
Yes, that is advisable. A thin layer of clear varnish or wood oil is often enough to protect against moisture, which can especially cause warping in spruce. If possible, treat the molding strips before fastening and allow them to dry thoroughly.
sanjon
13 Nov 2024 09:22
I simply screwed metal brackets to the underside of my Billy shelf, which significantly reduced the sagging. For this, I use sturdy galvanized screws that hold well in the particle board.
ju_ren
13 Nov 2024 13:45
nubar schrieb:
the maximum load for permanent use is about 15 kg (33 lbs) without reinforcement and 18-20 kg (40-44 lbs) with reinforcement per shelf.
I have found the same. Additionally, I recommend securing the Billy shelf to the wall for higher loads to ensure better stability and to prevent tipping.
