ᐅ Finishing Cut Edges on BILLY Shelves – Tools and Techniques
Created on: 16 Mar 2016 08:23
Jerryzar
I’m planning to assemble a Billy shelf unit from IKEA, and as with many flat-pack furniture items, the cut edges – meaning the edges of the boards that you might need to trim yourself or the factory edges – can sometimes appear a bit rough or uneven. I would like to properly finish these cut edges so they not only look better but are also more durable and resistant over time.
I’m wondering which tools are best for this: Should I use sandpaper, beginner-friendly edge trimming kits, or are there special edging tapes that can be used to seal such cut edges? It would also be great if you could share tips on the exact procedure – how many sanding passes are ideal, and in what order should the steps be done?
I’d appreciate practical advice and suggestions that also suit people who are not professional furniture builders. Thanks in advance!
A little tip from the art of keeping things simple here – 🙂
I once tried to achieve a perfectly straight edge using just sandpaper, and what can I say? In the end, my arms got longer than the edges got straight ;-)
What helps: Use a sanding block right away, as it ensures even pressure and a consistent result.
If you then gently sand with a sanding block using 180-grit sandpaper, it will become really smooth and silky. After applying edge banding, the rule is: press firmly and patiently, don’t rush – sometimes a careful hand produces a nicer result than the most advanced technique. 😉
Enjoy your DIY project!
Playing the practical advocate here ^^
Personally, I’m not a big fan of complicated finishing on cut edges. Especially for simple furniture like BILLY, usually just sanding the edges properly once or twice is enough. If you don’t want to make the shelf a showpiece, you can really keep the effort low.
Edge banding is nice if the cut edges absolutely need to be sealed, but often it’s enough to sand the edge cleanly and, for example, apply some clear wood varnish. This way you get moisture protection, and the appearance is fine too.
Depending on where the shelf is placed – basement, living room, or office – the tolerance may vary anyway.
One point I’d like to raise here is the issue of durability versus purely aesthetic improvements.
That may be true, but when the edges are exposed, the particleboard absorbs moisture and the edges chip more quickly. These mechanical effects should not be overlooked. A simple edge banding or at least a clear varnish on the cut edge significantly extends the lifespan.
Also, just sanding the edges does not eliminate the risk. In the worst case, you smooth the surface but don’t remove the fibers or chips that result. So you always have to weigh aesthetics, protection, and effort.
Can anyone here share concrete long-term experience with edge banding on the BILLY shelf?
bareynaldo schrieb:
BILLY is meant to be an affordable, functional piece of furniture... a stylish finishing touch simply isn’t necessary
neo59 schrieb:
Can anyone here share concrete experiences regarding the long-term effects of edge banding on the BILLY shelf?Yes, I’ve dealt with several edge banding projects myself. The durability largely depends on proper application: using a high temperature when ironing on the banding and pressing it firmly ensures a lasting bond. I have been using edge banding on some shelves for almost three years, and no edges have come loose or worn out—even with frequent use.
It’s important to smooth the cut edge thoroughly beforehand, as irregularities can put the edging under tension and cause it to peel prematurely. Applying a clear coat afterwards provides additional protection.
So, clearly: if you plan to use the shelf long-term, edge banding is definitely worthwhile.
Thank you for the detailed answers!
@benonon
I haven’t cut the shelf yet, but I will need to trim some of the boards myself, so most of the cut edges will be fresh. Can I follow your advice exactly as you described—starting with coarse sanding, then finer sanding, possibly edge banding, and finally a protective varnish?
It's important to me that the cut edges are really durable since the shelf will be placed in a kitchen where it may be exposed to steam and occasional splashes.
@LEAH_TAN
I really like your tip about using a cloth when ironing; otherwise, I probably would have messed it up again. 🙂
Overall, it sounds like the combination of sanding and edge banding (or alternatively varnish/penetration treatment) is the most sensible approach.
One more question: How precise do you have to be when cutting with the saw? I have often read that scoring the cut line with a sharp knife beforehand can help prevent splintering. Do you have any recommendations specifically for these chipboards from the BILLY shelf?
@benonon
@LEAH_TAN
