ᐅ Using KALLAX as a Radiator Cover – Material Issues?
Created on: 21 Dec 2020 18:47
Tugau
Tugau
21 Dec 2020 18:47
I am considering using an IKEA KALLAX shelf as a radiator cover in my apartment because I want to improve the room’s appearance while also adding storage space. However, I am concerned whether the material—especially the particleboard or fiberboard—can withstand the higher temperatures and humidity generated by the radiator over time.
Has anyone had experience with these boards warping, swelling, or getting damaged when placed directly on or very close to a radiator? Are there any recommendations for protective measures or alternative solutions to ensure the shelf remains stable in the long term?
Thank you in advance for your insights and tips!
Fitigu
21 Dec 2020 20:33
Hello Tugau,
I’ll respond from a technical perspective: KALLAX is typically made from a combination of engineered wood panels (MDF or particleboard) with a melamine coating. These materials are generally not designed to withstand prolonged high temperatures or humidity.
The heat emitted by a radiator cover can cause the temperature of the panel to rise, which may lead to swelling of the material or damage to the coating. Moisture from the air or condensation can worsen this effect.
My recommendation: If you want to use KALLAX as a radiator cover, you should leave a gap of at least 5 to 10 cm (2 to 4 inches) between the heater and the shelving to allow air circulation. I also suggest adding extra protection—such as heat-resistant paints or attaching thin metal sheets behind the panel to prevent direct heat contact.
Also, be careful not to block air circulation completely, as this will reduce heating efficiency and could cause damage to both the radiator and the shelving over time.
In summary: Yes, material issues are possible but can be minimized with proper precautions.
kemeo68
22 Dec 2020 10:17
Fitigu schrieb:
KALLAX typically consists of a combination of engineered wood panels (MDF or particleboard) with a melamine coating.
That is true, but honestly, I find it a bit rigid not to place the shelf exactly where you like it just because of these “technical concerns.” I mean, if you use the cardboard-like particleboards as radiator covers, don’t be surprised later when the piece looks like a warped battlefield.
For those who do it anyway: don’t expect furniture that will last for decades. Moisture and heat are simply a no-go for these materials.
Fitigu schrieb:
Air circulation must not be completely blocked, otherwise heating performance decreases.
I often underestimate this: you “cover” the radiator, and the room doesn’t warm up. It just doesn’t work well and leads to higher energy consumption.
In short: KALLAX above the radiator is a nice idea, but unfortunately exposed to poor materials and inefficient from an energy standpoint.
Landontau
22 Dec 2020 14:02
Hello Tugau,
to answer your question more systematically, here is a brief overview of what you should consider when using a KALLAX shelf as a radiator cover:
1. Materials and Thermal Stress
- The panels are made of MDF or particleboard, which are sensitive to heat and moisture.
- Direct contact with the hot surface can cause warping or delamination of the melamine coating.
2. Moisture and Air Circulation
- Radiators usually produce warm, dry air during operation, but condensation can occur on cold days, especially with older radiators.
- Restricted air circulation leads to heat buildup, which further stresses the material.
3. Protective Measures
- Allow at least 10cm (4 inches) of space between the radiator and the shelf to reduce heat radiation.
- Attach heat-resistant films or thin metal strips on the inside surfaces to provide protection.
- Optionally, seal the surface with heat-resistant clear varnish.
4. Practical Tip
- Regularly check for early signs of material damage so you can respond promptly.
Conclusion: A KALLAX shelf can be used as a radiator cover if the spacing and protective measures are observed. In general, proper air circulation and minimized moisture should be ensured to prevent material damage. This requires maintenance and monitoring but is feasible.
I hope this helps you with your decision.
