ᐅ Using Billy Regal Sandpaper – For Which Types of Surface Imperfections?
Created on: 20 Jun 2019 08:37
Rimar
Rimar
20 Jun 2019 08:37
I would like to start a discussion on the topic "Using sandpaper on a Billy shelf – what types of damage is it actually suitable for?" Recently, I’ve noticed some small signs of wear and scratches on my Billy shelf, and I’m considering whether sandpaper might be a cost-effective and quick way to fix these. I’m especially interested in which kinds of damage can reasonably be treated with sandpaper – is it mainly superficial light scratches, or does it also work on dents or chipped edges?
Additionally, I’m wondering what grit level is appropriate for sanding the shelf material without damaging the paint or surface too much.
Perhaps someone has experience or tips on what to keep in mind so that the Billy shelf looks good again after treatment without needing a complete repaint. Thanks in advance for any advice and suggestions!
sonplo
20 Jun 2019 10:05
Hello Rimar,
Regarding your question about which types of imperfections sandpaper can be used for on the Billy shelf, I would like to point out the following: In my experience, sandpaper is mainly suitable for very light to moderate surface scratches that have not yet significantly damaged the paint or melamine coating.
It is important to use a very fine grit, ideally 400 or finer, to gently abrade the surface without scratching the material or breaking through the protective layer.
For deep scratches, dents, or chipped corners, sandpaper alone will hardly help, as these areas have surface deformation and often require filling with putty and repainting.
My tip: Always test on an inconspicuous area first to see if the paint dissolves too much from sanding. Then polish with a soft cotton cloth. This way, small signs of wear can be managed effectively.
neoJohnny
20 Jun 2019 16:49
sonplo schrieb:
In my experience, sandpaper is best suited for very light to moderate surface scratches
I can confirm that. When using sandpaper on Billy shelves, it’s important to remember that the material usually has a melamine resin coating, which is durable but can be easily damaged by sanding that is too coarse.
For most minor marks caused by light scratches or small bumps, sandpaper with a grit size of at least 600 to 800 is recommended. Using a lower grit carries the risk of leaving noticeable sanding marks on the surface.
Additionally, you should always sand in the direction of the grain and afterward protect and refresh the sanded area with an appropriate furniture polish or clear varnish.
For deep dents, broken edges, or extensive damage, repairing with wood filler or replacing the furniture part is usually the more sustainable solution.
CORYGAU
21 Jun 2019 09:17
neoJohnny schrieb:
For deep dents, broken edges, or widespread damage, repairing with wood filler or replacing the furniture part is usually the more sustainable solution.
I generally agree with this, but I would like to add that the surface of Billy shelves is not a traditional wood surface. Most models are coated with some type of laminate layer, which has limited mechanical durability.
For this reason, I need to qualify the recommendation: sanding with sandpaper always carries the risk of grinding through the laminate layer down to the substrate.
With this in mind, I am interested in experiences regarding whether—and how—this laminate coating can be cleaned or sealed afterward to prevent cracking or further damage.
Are there any established home remedies or surface treatments that can be applied after sanding without having to repaint the entire shelf? Or is the effort then comparable to a complete refurbishment?
praWarre69
21 Jun 2019 13:41
Hey everyone,
just adding a bit of color to the conversation ;-)
So, for small scratches on the Billy shelf, I find sandpaper really effective, but of course, the key is to sand gently! Fine grits are definitely your best friend here.
Rimar schrieb:
which grit is suitable for sanding the shelf material without damaging the paint or surface too much
My recommendation is grit 800 or finer – that usually removes the marks without turning the shelf into a rough surface 🙂
And hey: once you’ve sanded it down, treat the piece with some furniture polish to restore the shine and help keep new scratches from showing up so quickly.
But watch out! If the shelf has a broken edge or is deeply dented, sandpaper won’t help much. In that case, better head to the hardware store and get some edge paint or similar.
Good luck refreshing your shelf! And as the saying goes: “Scratches tell their own story,” but sometimes we prefer to rewrite it 😉
