ᐅ Retightening Screws on BILLY Shelving – How Often Is It Necessary?
Created on: 17 Aug 2022 10:37
timelina5
timelina5
17 Aug 2022 10:37
Some time ago, I assembled a BILLY shelf from IKEA and now I’m wondering how often the screws should be tightened again. During my research, I found different opinions: some recommend retightening the screws after a few weeks, while others say it’s only necessary with heavier loads. I would like to know what experiences you have had with this.
Is this more of a maintenance issue that should be done regularly, or is there a downside to tightening the screws too often (e.g., material fatigue)? I’m also interested in whether frequent retightening can cause problems with the threads in the panels. Any advice on the best approach, ideal time intervals, and helpful tips would be appreciated.
bapar
17 Aug 2022 12:03
Hello @timelina5,
Regarding your question: tightening the screws on a BILLY shelf depends on several factors, such as the load, humidity, and quality of assembly.
In general, furniture joints with dowels and screws tend to loosen slightly over time due to material stresses and repeated loading. The shelf is usually under load and in use – placing and removing books, occasional leaning – so mechanical stresses make a follow-up check reasonable.
As for the frequency, many experts recommend a first inspection no later than 4-6 weeks after assembly. During this time, the material settles somewhat, and uneven stresses usually balance out. After that, it is common to check all connections at least once a year and retighten if necessary.
The risk of tightening too often lies mainly in damaging the particleboard used for the shelves or side panels. If the internal thread in the wood is overstressed by repeated tightening, it can strip or enlarge, which seriously compromises stability.
Therefore, you should tighten gently and with the right amount of force – not too tight, but enough so the shelf stands firm and without play. Using a screwdriver with a torque limiter can also help prevent damage.
If you assembled the shelf according to the original instructions and there are no signs of excessive load or deformation, in my opinion, the intervals mentioned above are sufficient. How do you usually load your shelf? Are many heavy books stored on it?
I hope this helps.
Garry
17 Aug 2022 13:27
bapar schrieb:
Basically, furniture joints like those with dowels and screws tend to loosen slightly over time due to material stresses and repeated loading.
I want to emphasize exactly this: it’s best to tighten the BILLY bookshelf once shortly after assembly (about 4-6 weeks) and then at longer intervals of around one year.
Tightening it too often doesn’t help much and can actually damage the wood, as bapar mentioned. It’s also important not to press the bookshelf firmly against the wall to avoid transferring additional stress to the screws.
I have followed this practice in my household and have so far encountered no problems.
Lamar
18 Aug 2022 09:51
I find this discussion interesting, but I think retightening the screws on a BILLY shelf is sometimes overrated.
bapar schrieb:
Many experts recommend performing a first check no later than 4-6 weeks after assembly.
In my view, it really depends on how securely the shelf was assembled and how heavily it is used. If you build your shelf properly and don’t constantly move it around or load the shelves with heavy metal boxes, you probably won’t need to retighten anything.
I would even say: if the screws are tight after assembly, they usually don’t loosen without a reason—meaning something was likely missed during the initial build. And honestly, the shelf doesn’t have to be a high-end piece of furniture, just functional. In that sense, retightening is more of an optional extra. 😉
Of course, if you see it as a planned "maintenance measure," you can certainly do that—it won’t hurt. Just try not to be too obsessive about it.
