ᐅ Stabilizing IKEA Malm Furniture Without Drilling – Any Tips?
Created on: 25 Mar 2020 14:07
Sumin51
Sumin51
25 Mar 2020 14:07
I have several IKEA Malm furniture pieces at home that I would like to stabilize without drilling, as I live in a rental apartment and am not allowed to make holes in the walls or furniture. My main question is: What practical methods or solutions do you know or have successfully used to stabilize Malm furniture without drilling? I am especially interested in tips that both minimize the risk of tipping or wobbling and ensure the furniture stands firmly and securely without the use of screws or anchors.
I look forward to your experiences and recommendations!
fasefar
25 Mar 2020 14:13
Sumin51 schrieb:
What practical methods or solutions do you know or have you successfully used to stabilize Malm furniture without drilling?
That’s great that you’re looking for something like this! :-) Malm furniture is actually quite sturdy, but of course, the wobbling can be really annoying. I personally put small felt anti-slip pads under the furniture legs—they not only protect the floor but also prevent sliding.
You can also use furniture clamps or special tension straps that fit between the furniture body and the wall, without drilling. They’re flexible and work well if you don’t want to use nails or screws. Give it a try; I had great success with it! 🙂
sihau
25 Mar 2020 14:25
fasefar schrieb:
You can also use furniture clamps or special tension straps that are wedged between the cabinet and the wall without drilling.
This is a good approach. To add to that: For stabilization without drilling, non-slip rubber foam or silicone pads placed under the furniture legs are especially recommended, as they increase friction against the floor surface and help prevent slipping. Additionally, clamp stabilizers with locking tension mechanisms can securely fix furniture between floor and ceiling without damaging the wall.
It is important to pay attention to the maximum load capacity of these systems, as excessive pressure can deform the furniture frame. Another option is using high-adhesion tapes at contact points, though these may damage the furniture surface and should therefore be used with caution.
SUDAN
26 Mar 2020 09:37
Good morning,
I would like to respond with a structured proposal that requires no drilling and can securely stabilize your Malm furniture:
1. Base plates / Non-slip mats: Place thin, non-slip mats or rubber pads under each furniture leg. This prevents slipping on smooth floors and significantly improves stability.
2. Tension clamps between floor and ceiling: There are special furniture tension rods (e.g., stretch clamps) that can be individually adjusted. Make sure to measure the furniture height and ceiling height precisely to set a secure tension without causing damage.
3. Furniture brackets with adhesive tape: If some wall stabilization is sufficient, brackets with double-sided mounting tape are a good option. They hold on clean, grease-free surfaces and can minimize wobbling.
4. Increase weight: Put heavy items in the lower drawers to lower the center of gravity and enhance tip resistance.
Important: Regularly check the tension of the clamps and the condition of the adhesive pads to avoid damage.
In summary: A combination of non-slip materials and special furniture tension rods provides good stability without drilling.
Franz
26 Mar 2020 18:54
SUDAN schrieb:
1. Base plates / non-slip mats: Place thin, non-slip mats or rubber pads under each furniture leg.
I can definitely confirm this – I was worried before that my Malm dresser was a bit wobbly, but with these pads it really feels much more stable now.
I’d also like to add that I personally tried positioning the furniture close to the wall and making sure the floor is truly level. In my experience, that often helps more than you might expect. For example, if you use rugs, placing flexible rubber mats underneath can also be beneficial.
sihau schrieb:
Another option is to use strong adhesive tapes at the contact points
I think that’s a good idea in principle, but I would be cautious because some adhesives can leave residue or damage veneers, especially on Malm furniture, which often has a laminated surface.
How have you dealt with this in your rental apartments? I’m curious to know!
