Hello, probably a silly question, but I’ll ask it anyway.
I currently have some fine gravel left over, which isn’t useful to me at the moment and mostly just gets in the way.
The base layer for the terrace is usually made with 0/32 gravel (probably to allow surface water to drain away).
Is it a bad idea to spread the finer gravel around the house and in the planned terrace area to level out uneven spots and fill holes so it gets used up?
Or would I create a barrier that could cause problems with surface water drainage later on?
Well, there won’t be a vapor barrier, but it doesn’t feel very comfortable to walk on either.
hampshire17 May 2020 10:09I would avoid using very fine gravel on the terrace, as you will carry it into the house on your shoes. You can mix it in if you have very clayey soil and are planting something. It also works as a "grit" for winter. If you don’t have space for it, it’s better to give it away to someone who can pick it up than to use it in a way that will cause you frustration later.
hampshire schrieb:
I would avoid using very fine gravel on the terrace, as you will carry it into the house on your shoes. You can mix it in if you have very clayey soil and are planting something. It also works as winter grit. If you don’t have space for it, it’s better to give it away to someone who can pick it up than to use it in a way that will cause you frustration later.On top of the fine gravel, about 20 cm (8 inches) of 0/32 (compacted) would be added, then 20-25 cm (8-10 inches) of edging stones as a border for the terrace. Inside these, there would again be 0/32 with 4-5 cm (1.5-2 inches) of fine gravel as a base layer for the terrace slabs, which are meant to be laid loose...
The question was whether the fine gravel (I think it’s 8/16) under the 0/32 would cause problems later...
hampshire17 May 2020 13:19He doesn't cause any problems there.
