ᐅ Smart ideas that make everyday life easier incorporated into the home
Created on: 20 Nov 2015 23:36
Slintrebla
We are currently in the construction phase of our single-family home. We are actively gathering ideas to make daily life in the new house easier.
So far, we have:
- A laundry chute from the bathroom on the upper floor to the washing machine in the basement
- A platform for the washing machine to allow easy loading and unloading
- Pantry shelving with rotating trays
We have also considered:
- Building a small utility room behind the living room cabinet (sideboard) to house all the TV equipment (satellite box, DVD player, receiver, hard drive, etc.) out of sight
To illustrate, I’m attaching three photos.
Maybe some of you have a nice REALISTIC idea that could be implemented.
Thank you in advance for your ideas!
Slintrebla
Washing machine with open drum, blue laundry basket, and cleaning products in the laundry room.
Bathroom with built-in bathtub under a sloping ceiling, dark stone surface, and a red round pot.
Kitchen pantry shelves with canisters and stacked plates in cabinets
Sebastian79
23 Nov 2015 14:28
Eve, that just can’t be.
Grym
23 Nov 2015 14:30
Do you also have to work sometimes in your state-of-the-art home office? You always respond to other posts within seconds...
Grym
23 Nov 2015 14:34
That now depends on the answer to the question...
Sebastian79
23 Nov 2015 14:36
Yes, I also have to work.
Doc.Schnaggls
23 Nov 2015 16:15
our “conveniences” that make life easier are:
- USB outlets to charge smartphones or tablets (however, you need to check exactly how much power the device draws while charging – our USB outlets each have two ports but can only charge one device from the company with the bitten apple at a time, otherwise the maximum power is exceeded and a safety shutdown occurs…)
- Three-phase power supply in the garage and hobby room
- Sufficient outdoor outlets with switches controllable from inside
- Enough power outlets, multimedia connections, and light fixtures
- Cistern with ground-level taps and automatic pump activation
- Wiring for the surround sound system
- LED nightlights with dusk sensors in the hallway and bathroom
- Paving that allows most of the rainfall to infiltrate => saves a lot on wastewater fees
Dirk
23 Nov 2015 21:58
Grym schrieb:
No, I don’t feel any joy or enthusiasm when I have appointments with craftsmen, more like a necessary evil.
Then you probably shouldn’t build your own home! I say that honestly and without sarcasm!
BeHaElJa schrieb:
I’m also not happy when the craftsman or delivery service is expected on Monday between 10 a.m. and 5 p.m…
No one enjoys that. So far, I’ve only experienced such open appointment windows with delivery companies or freight forwarders. I’ve never seen a tradesperson take this kind of “freedom”: arriving half an hour late is manageable. After all, you want something from them too…
Grym schrieb:
Some friends, for example, had a fireplace built by a bricklayer from their family at material cost and say that the furnace was only used twice last winter and they would never have installed it if…
You shouldn’t compare apples to oranges here—that is, don’t assume someone else’s experience applies directly to yourself.
Grym schrieb:
The fireplace produces heat like a radiator – not pleasant.
Yes, it is pleasant! Besides the slow response time of underfloor heating, many people have the problem that it doesn’t emit radiant heat. In this case, the fireplace can be a small “compensation” if needed, for example after a frosty walk or some cold outdoor activity, to light the fire and feel the radiant warmth on your body. Others use the built-in sauna or a hot bath instead – but these two alternatives have the drawback of being short-lived.
Grym schrieb:
Focused in one spot, instead of evenly heating the whole house (underfloor heating).
A fireplace should only be seen as a supplement—not as a replacement for a (conventional) room heating system.
Grym schrieb:
By the way, 2-5 times (use) is already enough to make the glass look awful.
I have to agree with a previous commenter: if you burn properly with good wood, this doesn’t happen often. My husband cleans the glass twice during the heating season. During the transitional period before heating starts, we have the fireplace going about three times a week—our neighbors have been freezing inside the last few weeks (outside temperature around 7–12°C (45–54°F)) because their heating didn’t turn on…
BeHaElJa schrieb:
Everyone should be happy with whatever they like.
Exactly!
Jochen104 schrieb:
Regarding the socket for an electric car
I think that’s a good and forward-looking idea: costs should be manageable and you will need it later. Great! We didn’t think of that.
