ᐅ Safely Mounting IKEA Metod Wall Cabinets on Drywall and Concrete Walls
Created on: 5 May 2020 18:17
ranopa
ranopa
5 May 2020 18:17
I am planning to install IKEA Metod wall cabinets in my kitchen. The wall is partly drywall (plasterboard) and partly concrete. My specific question is: How can I securely and permanently mount the Metod wall cabinets to both drywall and concrete walls so that they remain stable even under heavier loads (e.g., fully loaded cabinets) without risking detachment or damage to the wall?
I am interested in suitable anchors, screws, and fastening techniques for both types of walls. Are there any special tips to consider, especially when drilling, installing anchors, and calculating load capacity? I have some experience with drilling and installation but want to find a robust solution that minimizes errors specifically for the drywall/concrete wall combination.
Thank you in advance for any helpful advice!
Jeanbar
5 May 2020 19:02
Hello ranopa,
First of all, great that you asked your question in such detail! That’s really important because drywall and concrete walls behave very differently and therefore require different fastening methods.
For drywall, the general rule is: cabinets must always be mounted to the supporting framework (studs made of wood or metal profiles). Screwing “only” into the drywall board is not secure—no matter which anchors you use, the load from fully loaded wall cabinets is too great. It’s best to locate the studs using a metal or wood stud finder, depending on what’s behind the drywall. Then use wood screws or metal construction screws long enough to provide a solid hold.
For drywall anchors, if you have no option to screw directly into the studs behind the cabinet, special drywall anchors (e.g., toggle bolts, wing anchors, hollow-wall anchors) are available—but these are only partially load-bearing. I would strongly advise against using them for heavy wall cabinets like Metod units.
For concrete walls, I recommend heavy-duty anchors such as wedge anchors or metal expansion anchors. These offer high load capacity and durability. It is important to use a hammer drill and drill the hole as cleanly as possible. Then choose high-quality anchors in the appropriate size (usually at least 8 mm (0.3 inches) for heavy loads).
Important: Always work with a spirit level and possibly a hanging rail system—this can distribute the load more evenly.
One more tip: use a drilling template or marking strips to precisely prepare the anchor holes on the wall. This will save you a lot of trouble when hanging later.
If you like, I can provide you with more detailed product recommendations. Good luck!
TEBILO
6 May 2020 09:44
Hello ranopa,
I would like to provide a more detailed explanation about mounting the IKEA Metod wall cabinets on drywall and concrete walls, as I share the view that such installations should be truly solid and secure.
For drywall:
- You should always ensure that the screws engage in a load-bearing substrate, meaning the metal studs or wooden framing behind the drywall panel.
- It’s best to use a reliable stud finder to locate these, and then use long wood screws (at least 6x80 mm (1/4x3 1/8 inches)) that penetrate deeply enough.
- If no stud is found, even the best cavity anchors are insufficient for the weight of fully loaded Metod wall cabinets. There is a high risk of failure.
For concrete:
- Ideally, use metric heavy-duty anchors (e.g., M8 or M10).
- A hammer drill, dust collection for drilling debris, and thoroughly cleaning out the drilled holes are necessary.
- Make sure of the correct embedment depth and proper installation of the expansion anchors (the parts should expand inside the hole).
Another important point is load distribution:
- IKEA Metod wall cabinets should preferably not be supported by individual mounting points but fixed to a stable mounting rail, which is then securely anchored.
- This distributes the weight across several anchors, greatly enhancing safety.
In conclusion:
I advise you to pay close attention to the maximum load capacity of each type of anchor. A fully loaded Metod cabinet can easily weigh 20–30 kg (44–66 lbs) or more.
If you can provide details about the width and weight of your cabinets, I can suggest suitable anchor sizes and the minimum number of mounting points needed.
Regarding your question:
“Are there special tips to consider when drilling, inserting anchors, and calculating load?”
Yes:
- Drill holes straight. Even small deviations can prevent anchors from holding properly.
- Remove drill dust. Dust significantly weakens the connection.
- Distribute loads as evenly as possible across multiple anchors.
- For cavity walls (drywall), only screw into load-bearing studs; otherwise, additional reinforcement is necessary (e.g., attaching wooden battens behind the drywall).
If you wish, I can gladly prepare a materials list or explain the procedure step by step.
Best regards!
nanidra
7 May 2020 21:39
ranopa schrieb:
The wall is drywall in some places and concrete in others.
The exact problem is this: The wall cabinets are mounted on two completely different wall types, which hardly allow for a shared solution if you consider just the “classic” approach.
Here’s how I see it: Most tradespeople recommend always screwing into the framing (the studs or profiles) behind drywall. That sounds practical and safe, but think realistically: How often do you have metal studs running exactly behind your drilling points?
Jeanbar schrieb:
“Only” screwing into the drywall is not secure—no matter which anchors you use
Perfectly said. Still, you often hear that “X-anchors” or “super drywall anchors” can handle it—that, in my opinion, is a myth that falls apart as soon as one of the cabinets with some serious weight is hung and someone shakes the wall.
My provocative suggestion: If you don’t have a wooden backing panel behind the drywall or can’t install horizontal bracing in the wall, it’s better to reinforce generously before you halfheartedly screw into such different wall types. Even if concrete feels like a monster to deal with, a properly installed heavy-duty anchor here really provides safety.
I’d almost say, expect the worst, don’t expect much from drywall alone, and always plan to transfer the load fully onto the concrete—that’s ultimately in your control when arranging the cabinets.
So: The secret is to never treat drywall as a load-bearing surface but to keep fastenings there to an absolute minimum or (even better) add bracing. Otherwise, your IKEA dream could turn into a wall cabinet nightmare. 😉
