ᐅ Securely Mounting IKEA Metod Wall Cabinets on Different Types of Walls
Created on: 14 Sep 2022 18:23
Danma
Danma
14 Sep 2022 18:23
Hello everyone, I am currently facing the challenge of securely mounting IKEA Metod wall cabinets on different types of walls. Since my apartment has various wall constructions – concrete, drywall (gypsum board), and partly brick walls – I would like to know which specific mounting methods and materials I should use for each to hang the cabinets stably and safely. It is especially important to me not to cause damage to the walls, while still ensuring that the cabinets hold firmly under full load.
Does anyone have particular expertise or experience with this? Are there specific anchors or screws you would recommend? And what should be absolutely considered when mounting on different wall types, for example regarding screw length, the type of fasteners, or the placement of wall anchors?
Thanks in advance for your advice!
Tinaneo
14 Sep 2022 18:59
A very relevant question, especially since improper fastening is often reported with Metod kitchens.
Danma schrieb:
Does anyone have particular expertise or experience to share? Are there specific anchors or screws you would recommend?
Basically, I would advise never to use the standard anchors provided, especially on drywall or other hollow walls – these are often only suitable for light loads. Instead, you should choose heavy-duty anchors or special metal expansion anchors. For concrete walls, drop-in anchors or chemical anchors are the safest option.
However, I wonder if the IKEA installation manual is practical enough. Who has actually done load testing? In theory, sturdy kitchen wall cabinets can easily hold 30-40 kg (65-90 lbs), but of course that depends on the fastening.
Also important: the maximum allowable load per anchor should never be exceeded, otherwise you’ll soon end up with a wall full of screw holes.
Luchen
14 Sep 2022 19:07
For concrete walls, I recommend hammer-in anchors; for drywall, hollow metal anchors; and for brick, combined anchors depending on the wall thickness. Choose screws that are long enough to be anchored about 6 cm (2.5 inches) into the wall. In any case, make sure to follow IKEA’s installation instructions carefully.
draleo
14 Sep 2022 20:32
In addition to the previous answers, here is a structured overview for the safe installation of IKEA Metod wall cabinets:
- Concrete wall: Using hammer-in anchors (6-8 mm diameter, depending on the screw) or chemical anchors is particularly suitable. Screws should have an embedment depth of at least 6 cm (2.4 inches) in the material.
- Brick wall: Heavy-duty plastic anchors with at least 6 cm (2.4 inches) anchoring depth or special brick anchors. If masonry is suspected behind, pre-drilling and sealing is essential.
- Drywall (plasterboard): Use hollow wall metal anchors, toggle bolts, or special toggle anchors with specified load capacities. The maximum load rating of the anchors should be matched to the weight of the cabinet plus its contents.
- Screw length: Always choose screws long enough to fully engage the anchors and ensure sufficient load-bearing capacity.
- Installation materials: IKEA often provides screws and anchors for standard walls. These are usually unsuitable for drywall.
Additionally important: For wall cabinets, always ensure even load distribution by using multiple fixing points to spread the load. It is advisable to carefully consider the total weight, including contents.
teyosef
14 Sep 2022 21:45
To present the process technically and step by step:
1. Check the wall: Identify the type of material and its load-bearing capacity. For unknown materials, pre-drill and, if needed, use a cavity detector.
2. Select fastening anchors:
- Concrete: hammer anchors (6–8 mm) or chemical anchors
- Brick: special plastic anchors, possibly longer lengths
- Drywall (plasterboard): toggle anchors or hollow-wall metal anchors with specified load ratings
3. Screw length: Always choose screws so that at least 5–6 cm (2–2.5 inches) are anchored in solid material. This ensures load capacity.
4. Use a mounting rail: IKEA Metod wall cabinets are usually mounted on a mounting rail, which should be fixed with at least three, preferably four fasteners.
5. Test anchors: Before loading, test by pulling on the fastener or lightly loading the cabinet.
6. Consider the load: Empty cabinets are lighter, but a loaded door may weigh more than 20 kg (44 lbs), so size anchors accordingly.
7. Compare IKEA’s installation instructions with your own fastening materials to ensure the cabinets hang securely and level.
A small tip: Use a spirit level more often to ensure neat and precise work.
PECLARISSA
15 Sep 2022 09:17
I had drywall installed and didn’t want to use cheap nylon anchors because I was worried the cabinets might eventually fall down. Instead, I used toggle bolts, which hold really well, and I was able to quickly and neatly install everything using the mounting rail provided by IKEA.
A small upgrade that was worth it: use metal screws, not zinc-plated ones, as those are often softer and rust more quickly. For drywall, you need screws at least 6 cm (2.4 inches) long; otherwise, they won’t hold properly. I initially had problems with screws that were too short.
Important: pre-drill with a sturdy drill bit before mounting, otherwise the drywall will break out too easily.
